Hello All,
I found this code at Kean Walmsley's blog [here]
It works just fine, however I'm having some trouble adapting the code.
I do not want to pick a block, I want to use a specific named block.
e.g (blk.Name = "MyBlock" or Blk.Name = "MyOtherBlock")
I started commenting some of it, but when I get Dim selSet As SelectionSet = res.Value I get lost.
How can this be done?
Imports Autodesk.AutoCAD Imports Autodesk.AutoCAD.Runtime Imports Autodesk.AutoCAD.ApplicationServices Imports Autodesk.AutoCAD.DatabaseServices Imports Autodesk.AutoCAD.EditorInput Namespace MyApplication Public Class DumpAttributes <CommandMethod("LISTATT")> _ Public Sub ListAttributes() Dim ed As Editor = Application.DocumentManager.MdiActiveDocument.Editor Dim db As Database = HostApplicationServices.WorkingDatabase Dim tr As Transaction = db.TransactionManager.StartTransaction ' Start the transaction Try ' Build a filt
er list so that only ' block references are selected Dim filList() As TypedValue = New TypedValue() {New TypedValue(CType(DxfCode.Start,Integer), "INSERT")} Dim filter As SelectionFilter = New SelectionFilter(filList) Dim opts As PromptSelectionOptions = New PromptSelectionOptions opts.MessageForAdding = "Select block references: " Dim res As PromptSelectionResult = ed.GetSelection(opts, filter) ' Do nothing if selection is unsuccessful If (res.Status <> PromptStatus.OK) Then Return End If Dim selSet As SelectionSet = res.Value Dim idArray() As ObjectId = selSet.GetObjectIds For Each blkId As ObjectId In idArray Dim blkRef As BlockReference = CType(tr.GetObject(blkId, OpenMode.ForRead),BlockReference) Dim btr As BlockTableRecord = CType(tr.GetObject(blkRef.BlockTableRecord, OpenMode.ForRead),BlockTableRecord) ed.WriteMessage((""& vbLf&"Block: " + btr.Name)) btr.Dispose Dim attCol As AttributeCollection = blkRef.AttributeCollection For Each attId As ObjectId In attCol Dim attRef As AttributeReference = CType(tr.GetObject(attId, OpenMode.ForRead),AttributeReference) Dim str As String = (""& vbLf&" Attribute Tag: " _ + (attRef.Tag + (""& vbLf&" Attribute String: " + attRef.TextString))) ed.WriteMessage(str) Next Next tr.Commit Catch ex As Autodesk.AutoCAD.Runtime.Exception ed.WriteMessage(("Exception: " + ex.Message)) Finally tr.Dispose End Try End Sub End Class End Namespace
I'm trying to automate it to list the attribues from a list of specific blocks.
I dont want it to prompt the user to select a block.
ok you can try with following code.
With the below routine, you can get object ids of all block.
public static ObjectIdCollection BlockReferenceInModelSpace(Editor acEd) { //get block reference TypedValue[] tvs = new TypedValue[1]; tvs.SetValue(new TypedValue(DxfCode.Start, "INSERT"), 0); SelectionFilter sf = new SelectionFilter(tvs); PromptSelectionResult psr = acEd.SelectAll(sf); if (psr.Status == PromptStatus.OK) { return new ObjectIdCollection(psr.Value.GetObjectIds()); } else { return new ObjectIdCollection(); } }
main sub:
public void TEST_Attribute() { Document doc = Application.DocumentManager.MdiActiveDocument; Database db = doc.Database; Editor ed = doc.Editor; //get object id's of all block in the active drawing ObjectIdCollection objIdColl = BlockReferenceInModelSpace(ed); //lock document using (DocumentLock docLock = doc.LockDocument()) { //start transaction using (Transaction tx = db.TransactionManager.StartTransaction()) { //iterate object id foreach (ObjectId objId in objIdColl) { //get the obeject Entity ent = tx.GetObject(objId, OpenMode.ForRead); if (ent is BlockReference) { //casting block reference BlockReference br = ent as BlockReference; //'now check the block name here if (br.Name == "MyBlock") { //' if block name satify then check atttrubute foreach (ObjectId attId in br.AttributeCollection) { //do as you like } } } } } } }
you can try with this code. hopefully would help to serve your purpose
