.NET
Can to start a new project
3 REPLIES 3
228 Views, 3 Replies
Can someone please explain how to start a new project for a standalone app.
I cant seem to get the references and declarations i need to do anything,
thanks!
3 REPLIES 3
Generally, the .NET wrappers can't be used to create stand-alone
applications.
I say "generally" because strictly speaking, you can use the managed
wrappers in conjunction with RealDWG (aka ObjectDBX) to create a stand-alone
app; but RealDWG isn't readily available as it must be licensed from
Autodesk. If AutoCAD is installed on the machine, you can use COM
automation in a stand-alone app, but that has nothing to do with .NET;
although you can use a .NET language to work with the AutoCAD automation COM
objects.
Dan
"Bob" wrote in message
news:5204263@discussion.autodesk.com...
thanks!
so are you telling me that i cant automate autocad from vb.net?
maybe my original question wasnt clear.
what is the equivalent code for vb.net that i use in vb6?
"J. Daniel Smith" wrote in message
news:5204557@discussion.autodesk.com...
applications.
objects.
Dan
thanks!
A good starting point would be the vb.net sample in the following directory:
C:\Program Files\Autodesk Product 2007\Sample\Product API\VB_NET\VbDotNetClient
(the path will vary depending on the version/vertical product installed)
Another good resource are the help files that are in the ObjectARX Help files and samples, look for "dotnet" folders.
http://usa.autodesk.com/adsk/servlet/item?siteID=123112&id=773180
Good luck
If you would like additional assistance email me
civil3d.net<(at)>gmail.com
”Boost
