Yes, it is part of RealDwg, but you need AutoCAD to use that (use that
INSIDE AutoCAD).
"J. Daniel Smith" wrote in message
news:5018994@discussion.autodesk.com...
I suspect "acdbmgd.dll" is part of RealDWG, so .NET should be an option in
that enviroment.
Dan
"Norman Yuan" wrote in message
news:5018964@discussion.autodesk.com...
A *.dwg file can only be created by AutoCAD (unless you are registered
ObjectDBX, now kown as RealDWG, developer, which requires C++, not .NET
managed code). So, to your question, you can only do it if you/your user
have AutoCAD installed, you app (written in .NET C#/VB.NET or non-.NET
language) just makes/automates AutoCAD to create a *.dwg file.
wrote in message news:5018799@discussion.autodesk.com...
Hello everyone!
I've got some questions
a) I need a .NET application (not dll library) with C# that generates a dwg
drawing, is it possible?
b) If it's possible, what I need?
Thanx
