.NET
application is busy in customized version of Script Pro 2
1 REPLY 1
wesbird
995 Views, 1 Reply
I'm modified Script Pro 2 from autodesk lab. Now I have this problem, sometimes, I got this error message
"The message filter indicated that the application is busy. (Exception from HRESULT: 0x8001010A (RPC_E_SERVERCALL_RETRYLATER))"
at
object ret = ActiveDocument.GetType().InvokeMember(
"SendCommand",
BindingFlags.InvokeMethod,
null, ActiveDocument, OnedataArray
 or
short fd = (short)ActiveDocument.GetVariable("FILEDIA");
 ActiveDocument come from
ActiveDocument =
AcadDocuments.GetType().InvokeMember(
"Open",
null, AcadDocuments, ThreeVariable
I understand those are out-process call. Maybe AutoCAD is still doing something when it happens. right now I increase the wait time right before the call like:
Thread.Sleep(100) -> Thread.Sleep(500)
what should I do to avoid this problem.
Wes
Windows 10 64 bit, AutoCAD (ACA, Map) 2023
1 REPLY 1
Virupaksha_aithal
in reply to: wesbird
I suggest you to use IsAcadQuiescent() before sending the command to AutoCAD. IsAcadQuiescent is implemented in ScriptPro specifically to check for AutoCAD state.
Virupaksha Aithal KM
Developer Technical Services
Autodesk Developer Network
”Boost
