1. I have the project set in Visual Studio with the default class Class1.cs and 4-5 CommandMethods. I would like to add some more methods, but not in the same file, because I get bored scrolling. I created a second class, but when I try my commands in autocad, I receive Unknown Command .
2. How can I add the netload command as a button, somewhere visually, without entering the command netload.
3. Any more updates for NetUnload solutions, beside this: http://through-the-interface.typepad.com/through_the_interface/2008/09/tired-of-not-be.html
Thank your for your time and your responses! ๐
1) look at the partial keyword, If you want them in the same class but different files.
otherwise just define the commands in another class in the new file.
2) the same as you define any other toolbar/menu button.
3) not possible.
// Called Kerry in my other life.
Everything will work just as you expect it to, unless your expectations are incorrect.
class keyThumper<T> : Lazy<T>; another Swamper
1. Ok. I found that I didn't add this line [assembly: CommandClass(typeof(MyFirstProject1.ClassName))] to my new class and that's why it didn't work.
2. I pressed right click on the toolbar and I choosed Customize and after that All Commands and Controlls, but the netload command is not there...
3. Ok
P.S. Thank your response!
You could add an alias like the letter "N" to your Acad.pgp file. This way you just have to type N to launch NetLoad.
