When I'm measuring around the model in Navisworks I'm constantly having to change my FOV for various reasons. Is it possible to designate buttons on my keyboard or spare buttons on my mouse to control this in stead? It would make things much smoother!
Solved by brett_parkerLUEP7. Go to Solution.
Thank you for posting to the forums.
One option is to use 'Keytips'. With keytips (alt shortcut) you can click;
See video attached.
Depending on the mouse you use, some mice come with the ability to assign macros to a mouse button. This sequence could be added to a macro so that this can be done even faster.
Hope this helps.
