Navisworks Forum
Welcome to Autodesk’s Navisworks Forums. Share your knowledge, ask questions, and explore popular Navisworks topics.
NWD export
6 REPLIES 6
34647 Views, 6 Replies
NWD export
Dear community.
I currently use Autodesk Revit 2014. I would like to export .rvt file to .nwd file (naviswork) but I don't know how to do.
Anyone can show me?
Thank you very much
6 REPLIES 6
danielkazado
 To have *.nwd file from *.rvt file;
  • Open Navisworks and Open the Revit file in Navisworks.
  • You will see this will create a cache  file with the same name *.nwc in the same folder.
  • Than save the navisworks file and select *.nwd for the file extension.
  • You may append more revit files to the same *.nwd if require.
Daniel Kazado
Please use Accept as Solution if your question is answered.
You may Give Kudos if the answer is helpful.
OR, if you have Navisworks installed after and on the same computer, you should have a plug-in in Revit to export as NWC file. This NWC file contains more properties than the one that would be created by the process explaind by Daniel.
Next steps are the same: Start Navisworks.
Append the NWC files you need.
Save AS NWD.
You could also Publish as NWD and then the NWD can have a password and even an expire date.
dgorsman
in reply to: Patrick_Aps_9121
More generally you need either Navisworks Simulate or Manage available to publish an NWD file.  It cannot be done straight from Revit.
in reply to: dgorsman
Thank you very much for the helpful answer
Can I apply  the same with linked Revit models?
hi dgorsman
is this still the case that you need either navisworks simulate or manage to publish a .NWD file?
thanks, Alina
Rail Community
