When I import ADT Files (Walls, clean-room-ceilings etc) I can see only 2D Informations...
When the "sender" exports it to "Autocad"=Exploding the Structure I see all 3D Objects!
Is that necessary?
Workaround?
You cannot directly import an ADT model into revit as ADT objects are not Revit objects and vice versa. Going out via Autocad and then into Revit will work, or you could create a Generic Family of the Autocad geometry and load that into Revit as one big family.
Use your judgment on the best option. Thanks for posting.
Can you post the file on an FTP site or Dropbox and give me the address. I will download and test. Thank you.
