Navisworks Forum
Welcome to Autodesk’s Navisworks Forums. Share your knowledge, ask questions, and explore popular Navisworks topics.
Animation Export – missing objects - 20090902
5 REPLIES 5
821 Views, 5 Replies
Greetings,
I am trying to export a short animation walkthrough from Navisworks. Using “presentation” mode, some objects are rendered as black. I have found this to be the case in AVI, PNG, and JPEG exports. Has anyone else experienced this?
- CL
5 REPLIES 5
Cosgrovedt
I have had the same problem importing MEP in Navisworks, i got a round it by using presenter to add a material/ colour to all the valves.
In the Presenter tab, try deleting the material called "By Layer". This has worked for me in the past.
hi all
Hi all,
I'm making a walkthrough animation. A 1024x768 (screen resolution) movie but still after exporting into avi, it can't be played. It says it is corrupted.
This is the setting: OpenGL, Windows AVI, 30 fps, Anti-aliasing: 4x, Explicit, Width: 1280,Height: 1024.
And it takes longer time durign exporting.
What's the best configuration? I need you suggestions..
Thanks all..
michael.lorek
I have exactly exactly the same issue, did you find a solution for it?
I can export the video, it takes normal the usual hours to export but then when I play it, it plays just a black clip
Rail Community
