Navisworks API
Welcome to Autodesk’s Navisworks API Forums. Share your knowledge, ask questions, and explore popular Navisworks API topics.
Using existing searchsets w/ API
4 REPLIES 4
707 Views, 4 Replies
I have many searchsets that are/will be defined by the user through navisworks UI.
I would like to use these existing searchsets for further actions. preferably reach those existing searchsets by their display name (as defined by their creator-the user).
Every written/help material I've found so far (documentation, xiaodong's blog..) only refered to generating "new searchsets" by defining conditions on the code.
any guidance will be appreciated.
4 REPLIES 4
appinfo did the trick. got what i needed.
ritikk_TWEMT4ENWAYA
@Anonymous Can you please share the solution in details please, facing the same issue
Hi @ritikk_TWEMT4ENWAYA ,
Please take a look at this below code
 Document doc = Autodesk.Navisworks.Api.Application.ActiveDocument;
            SavedItemCollection searchAndSelectionSets=doc.SelectionSets.Value;
            IList<SavedItem> requiredSearchSets = new List<SavedItem>();
            foreach(SavedItem savedItem in searchAndSelectionSets)
                SelectionSet selectionSearchSet = savedItem as SelectionSet;
                if(selectionSearchSet.HasSearch)
                    //Check whether SelectionSet.HasSearch value
                    //If "true", it is a "Search Set"
                    //If "false", it is a "Selection Set"
                    requiredSearchSets.Add(selectionSearchSet);
            foreach(SavedItem savedItem in requiredSearchSets)
                SelectionSet searchSet=savedItem as SelectionSet;
                ModelItemCollection modelItemCollection= searchSet.GetSelectedItems();
                foreach(ModelItem modelItem in modelItemCollection)
                    //Access Search Set Model Items here
I hope this helps.
Naveen Kumar T
Developer Technical Services
Autodesk Developer Network
Yes Thanks @naveen.kumar.t It Works.
Rail Community
