Hi all,
I'm trying to open/append Inventor files thru the API (using SDIViewer example). What I get is a SceneConvertServer.exe error "The program can't start because lcutil.dll is missing from your computer. Try reinstalling the program to fix this problem". I tried this on a computer with a clean install, same result.
When I do this manually in Navisworks, everything is ok, Inventor file is loaded, sceneconvertserver runs correctly, file gets displayed.
Is there some code I need to add for the converter to run properly?
Leszek
NW2014 SP1
