MotionBuilder Forum
Welcome to Autodesk’s MotionBuilder Forums. Share your knowledge, ask questions, and explore popular MotionBuilder topics.
setting keys on specified objects
4 REPLIES 4
1350 Views, 4 Replies
Hi !
Could anyone help me on how to set keys on multiple specified object(ex.: locator*) if there is no keys yet.
I tried with some example from ther forum but i'm not a programmer so i got stuck.Here is my try :
from pyfbsdk import *
lScene = FBSystem().Scene
iValue = 10 # sample value
iFrame = 10 # sample value
def FindAnimationNode( lScene, pNode ):
print("test first")
lResult = None
lName = pName.split( '/' )
for lNode in pNode.Nodes:
print("test second")
if lNode.Name == lName:
if len( lName ) > 1:
print("exist")
lResult = FindAnimationNode( pName.replace( '%s/' % lName, '' ), lNode )
else:
print("not exist")
lResult = lNode
break;
return lResult
def KeyAnimation( pName, pDst ):
print("test third")
lAnimNode = FindAnimationNode( pName, pDst.AnimationNode )
print("test fourth")
if lAnimNode.FCurve:
for lKey in lAnimNode.FCurve.Keys:
lAnimNode.KeyAdd( 10, 10 )
for lcon in lScene.Components:
if lcon:
# searching for constraint with locator in name
if lcon.Name.find("locator") != -1:
lDst = lcon.Name
print (lcon.Name)
KeyAnimation( 'Lcl Translation/X', lDst )
there is an error message : 'str' object has no attribute 'AnimationNode` (in line 28:lAnimNode = FindAnimationNode( pName, pDst.AnimationNode ))
thanks in advance
Ashraf
4 REPLIES 4
_KxL_
Can you describe what you want to do? Where you want to set key, and for what kind of objects?
Here is a quick script for placing an key ( x15,y10,z50 ) on selected models translation curve. To test: add cube to scene, select it, and run script:
from pyfbsdk import FBModelList, FBGetSelectedModels, FBPropertyManager, FBVector3d
def SetKey( pAnimationNode, pValue):
pAnimationNode.Nodes.KeyAdd(pValue)
lModelList = FBModelList()
# Get the selected models.
FBGetSelectedModels( lModelList )
for lModel in lModelList:
SetKey(lModel.Translation.GetAnimationNode(), FBVector3d(15,10,50))
# Cleanup.
del( lModelList, SetKey )
del(FBModelList, FBGetSelectedModels,FBPropertyManager, FBVector3d)
Hi !
First of all thank You very much for Your help.
I tried to set keys on Nulls on translate X,Y,Z all the null has a prefix "locator" +counter.My main purpose is to key all nulls named "locator" without selecting them.
I tried to implement Your Code ,but whwn it comes to the for loop it stops with an error:iteration over non sequence.Maybe FBGetSelectedModels does not returns an array?
Thank You again
Ashraf
from pyfbsdk import FBModelList, FBGetSelectedModels, FBPropertyManager, FBVector3d,FBModelTransformationMatrix,FBSystem,FBFindModelByName,FBModel
lModelList = FBSystem().Scene
lModelList = FBFindModelByName("locator" , None)
if lModelList == None:
print("None Found")
lModel.Selected = True
tvector = FBVector3d()
lModel.GetVector(tvector, FBModelTransformationMatrix.kModelTranslation)
SetKey(lModel.Translation.GetAnimationNode(), tvector)
# Cleanup.
del(FBModelList, FBGetSelectedModels,FBPropertyManager, FBVector3d, FBModelTransformationMatrix,FBSystem,FBFindModelByName,FBModel)
_KxL_
Sorry, but I am not sure if you know what you are doing. Function:
FBFindModelByName(...)
finds a model, not an list of models. So why you want to iterate it?
Evaluate this script. It should be close to what you are looking for:
from pyfbsdk import FBSystem, FBScene, FBVector3d
def LookInHierarchy(pRoot, pPrefix):
if pRoot:
if pRoot.Name.find(pPrefix)==0 :
SetKey(pRoot.Translation.GetAnimationNode(), FBVector3d(15,10,50))
for lChild in pRoot.Children:
LookInHierarchy(lChild, pPrefix)
LookInHierarchy(FBSystem().Scene.RootModel, 'locator')
# Cleanup.
del( LookInHierarchy, SetKey)
del( FBSystem, FBScene, FBVector3d )
SetKey does what it says. LookInHierarchy goes through scene models and looks for ones that name starts from 'locator'. When it finds it key is being set.
I do not know if you want to add key with given value or insert at given time. Check in FBAnimationNode and FBFCurve if you want some other key functions.
Thank You very much for the reply, this helped me a lot this was exactly i was looking for. Previously i thought FBFindModelByName returns a list so i was confused, now it's clear so thank You again!
