- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I'm having an issue with exporting a Patran file using Export -> Model -> (Patran file) in MF17.
The exported file has a slightly different format to the ones usually exported by MF.
Usually each coordinate is stored within 16 characters while in MF17 this not the case.
For example:
MF16: -1.250000000e-02 6.350000000e-02-3.000000000e-03
MF17: -1.250000000E-2 6.350000000E-2-3.000000000E-3
This difference makes the file unreadable in other softwares.
Using MPI2PAT would give the correct format in MF17. However, it would be nice to be able to export the Patran file using the export model command as it is and the outcome file a part of an automated process.
Can anyone please help me with this matter?
