Hi all,
Moldflow Image Capture Option quality poor compared with snip tool,
While capturing design areas like flange , ribs , boss we do zoom in more detail of respect areas, right that time image quality much poor,
Attached image file i have mentioned with red line inside mesh whitish colour,
Please provide your valuable suggestions,
Muthuraja
Solved by PascalGosset. Go to Solution.
I don’t agree with you.
I think the quality of the pictures created by Moldflow is good (I hope it’ll last.)
Look at the comparison I made.
It shows the same picture, enlarged 2 times, saved in Jpeg and Gif with Moldflow, Windows capture tool * and the software IrfanView. (*is it what you mean by “snip tool”?)
You can see the results got with Moldflow are not so bad.
Personally, I prefer the Gif format because it gives sharper colors and writings.
IrfanView works well enough.
Your picture is strange. I never saw that, edges missing.
I hope this reply will help you.
Signature: "Maybe Moldflow does not work properly, but the real world neither" my son...6 years old 😉
Hi Petr,
Thanks for the reply,
I do agree for your above comparison images results for filling shades,
can you check and post fill contour for the midplane meshes?
Muthuraja
So, this is a comparison of the filling contours displayed for a Midplane model.
My conclusions remain the same:
I made several tests to try to reproduce the defect you have.
I did not succeed.
But, now I think I had this problem a long time ago.
Which version of Moldflow do you use?
Is your graphics card driver updated?
Hi petr,
Thanks for the work u have done,
Now i can try to capture images from moldflow itself for report preparation,
we r using MF-2017.3- Graphicscard- NVIDIA Quadro P2000
Muthuraja
if using Nvidia graphics card, it many times improve performance by changing
Global Presets to “3D App – Visual Simulation”
First, update graphics driver.
Those topics are for different reason, but shows how to do this setting,
Global Presets to “3D App – Visual Simulation”:
Moldflow scale or legend bar missing when displaying results
Moldflow: Bounding box not visible when using select tools
It could also be so, that you maybe need to change opacity.
In the Plot properties, tab Mesh Display, Surface display, below Transparent, you can change Opacity.
Would try updating graphics driver, and set Global Presets to “3D App – Visual Simulation” first.
Hope this helps.
Berndt
