Moldflow Adviser Forum
Welcome to Autodesk’s Moldflow Adviser Forums. Share your knowledge, ask questions, and explore popular Moldflow Adviser topics.
DOE to minimize the mass ??????
4 REPLIES 4
Louis-PhilippeLePoul2125
759 Views, 4 Replies
One of the most important Quality factor among all is the part weight.
I don't understand why the goal of the Moldflow DOE is to minimize the mass !!!!!!! and why can't we change that to maximize??
The minimum mass is given by functionnal and structural constraints (and very basic plastic part design rules).
The guys down in the workshop do a good job when they reach the maximum weight with acceptable internal constraints for a given geometry.
Any idea ??
...and why can't we change that to maximize??
   LPLP
4 REPLIES 4
Hi Louis,
Why dont you post in Insight project? Optimization is itself mean that Optimal value of mass at which product can fuction well under life cycle stresses/ fatigue.
Mayur
Hi
I confirm I don't understand (accept) this concept of "minimizing the weight".
The goal of Moldflow Insight DOE is to optimize the process on the basis of a given geometry.
The process is optimized when the cavity is perfectly filled and packed, and the best judge for that is to increase packing and holding levels and holding time, and gate diameter in such a way that the weight doesn't change anymore (+/- 0.5% change is acceptable! ).
For a part having aspect constraints, maximum weight target means no sink marks.
For a more "technical" part having structural demands, maximum weight target means no voids, no porosities, good weld lines, homogeneous shrinkage and lots of more things which make a plastic part "good".
Moldflow says in DOE builder-Quality criteria-Total mass : " The lower the mass, the higher the quality". I do not agree.
Please Mister Moldflow, let me the possibility to change the "goal" from "minimize" to" maximize"
Let me know if this could change something in the results. If not, ..., I can forget that.
Thank you
Hi Luis-Philippe,
Within Midplane and Dual Domain, you can actually change the thickness, which would be a geometric change (see below)
However, beyond this point your point is valid; and certainly the comment on the dialogue stating that the lower the weight, the higher the quality, is certainly not necessarily true, and, as you pointed out in case gemoetric changes are not permitted, not correct. This should be corrected and we should allow the objecteve to be changed to maximize.
Hanno
Hanno van Raalte,
Product Manager - Injection Molding & Moldflow products
raalteh
in reply to: raalteh
Hi Luis Philippe,
If you contact me per email (hanno.van.raalte@autodesk.com) I can pobably help you enabling a 'mazimize' condition, instead of the minimize.
Hanno
Hanno van Raalte,
