Mockup 360 Forum (Read Only)
Welcome to Autodesk’s Mockup 360 Forums. Share your knowledge, ask questions, and explore popular Mockup 360 topics.
Mockup 360 Application failed to run
5 REPLIES 5
2940 Views, 0 Replies
Hi all,
I've having trouble getting mockup 360 to run. I double click the icon on the desktop, it says lauching aplication for a second then i get the splash screen for a moment then nothing.
I have tried installing from Firefox and Internet explorer and manually.
 Made sure my Virus scanner is off and windows fire wall, and user access control is off
I'm running Windows 8 64bit, Java is upto date 64bit version
Not sure what else to check? Or am I missing something obvious
5 REPLIES 5
joel.palioca
Hi GNR88,
Could you try deleting the 3 files and the Mockup360 folder in the path below and relaunch the product?
%Userprofile%\AppData\Local\Autodesk\Web Services
Please let me know if this helps at all or if you still have issues and we can follow up to see how to resolve this problem.
[Joel Palioca]
[Software QA Engineer]
Joel(dot)Palioca(at)autodesk(dot)com
in reply to: joel.palioca
I am now up and running
Thank you for your help!
If you need any more infomation to help stop this from happening to others let me know.
tks for share it
designer.shelleymorris
Why did the Mockup 360 Application fail? I have lots of works that needs to be done. Do you have any solution?
Shelley
contactJ2JUV
Ok nice  !
