Maya Programming
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya SDK topics.
MEL script newbie question
2 REPLIES 2
381 Views, 2 Replies
Can anyone help please?  I'm trying to write a simple MEL script that will ask the user for a number, then create that number of polycubes.  I can manage to do that and I've got validation so that the user can only input a number between 4 - 32.
However, when it comes to creating the cubes is where I am having difficulty in getting my head around the logic.
What I want to do is start with a specified polygon size (2.5,1,5) then have each successive polygon scale up in one dimension.  In addition to that I want to displace the cubes progressively so that in the end I have what looks like a staricase of cubes.
But... what happens is that although the right number of cubes is created, only one of them is moved to the position I want (so far I haven't tried the scaling).  I suspect I need to create a new variable to do it, but I am stumped as to how.
Any help will be very gratefully received
Rosanne
This is my code so far
global int $No_of_Cubes;
global proc makeCube(int $No_of_Cubes) {
    //Sets the $count variable as an integer
    int $count;
    for ($count = 0;  $count < $No_of_Cubes; $count ++)
    polyCube -w 2.50 -h 1 -d 5 ;
    move -y .5;
    //Trying to create shader - doesn't work
    //createAndAssignShader lambert "";
    //connectAttr -f lambert2.outColor lambert2SG.surfaceShader;
    //sets -e -forceElement lambert2SG;
    //displace cubes
    move ($count * .5) ($count *.25) 0;
//global proc buttonAction(){
    //else makeCube($No_of_Cubes);
    //buttonAction();
global proc makeCubeUI(){
        string $getNoCubes = `promptDialog -title "Mystery!"
     -message "Please enter a number between 4 and 32"
          -b "Click to see what happens next"`;
    string $getCubeString = `promptDialog -q`;
        int $No_of_Cubes = $getCubeString;
//validates $No_of_Cubes is > 4 or >32
//if yes, error message and reset
 //   int $No_of_Cubes;
    if (($No_of_Cubes <4)||($No_of_Cubes >32)){
            confirmDialog -t "Oops!"
        -m "Number must be between 4 - 32"
        -button "ok";
    makeCubeUI();
makeCubeUI();
2 REPLIES 2
Hi
It looks like you were quite close. Your problem was that you didn't put braces (the curly ones {}) after your for loop and so it was only looping over the first command (the polyCube command in this case). So to fix it I just added the braces. Your makeCube function now looks like this:
    int $count;
        move -y .5;
        //displace cubes
Hope this helps
Mike
Many thanks Mike - that fixed it beautifully
kind regards
Ros
