Maya Dynamics
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya dynamics topics.
goalU(V)PP attribute ...
3 REPLIES 3
Calebos
316 Views, 3 Replies
I have problem with particle setup when particles are running/sliding exactly on geometry along its UVs. There is no possibility to make particle attribute goalU(V)PP anymore. Is it possible to make this type of movement with another method, or not? There is several goal attributes when you create goal for the particle but no one of them(I mean "Create Goal World Tangent U(V) 0 PP" directly accessible in Attribute Editor) but none of them are useless for this ...
Thank you.
3 REPLIES 3
Calebos
in reply to: Calebos
Could any of official employees let me know if there is a problem with described issue, please?
I would like to know if this problem is painful bug or I am doing something wrong. In other words there is NO possibility to use goalUPP(VPP) anymore so is there anybody who can describe me some workaround or what is happenning on this field? I just need to set U or V goal individually for every particle, NOT per object, but per particle basis.
Thanks.
Calebos
Made it up a while ago. If needed delete this topic please.
n8skow
If you found a solution - please share for the benefit of other visitors.
