Inventor Publisher
Welcome to Autodesk’s Inventor Publisher Forums. Share your knowledge, ask questions, and explore popular Inventor Publisher topics.
Assembly narrative
2 REPLIES 2
824 Views, 2 Replies
Assembly narrative
Apologies if there's already a post for this. In the example files in Publisher, the grey bar at the bottom shows the same text as the lables but also gives detail on what's happening. For example, a snapshot will be titiled Step 1.4 but the grey bar shows some text saying 'Assemble threaded alignment nuts'. I cant work out where this text comes from though?
Alan
2 REPLIES 2
LeoWan
Hi alslater,
This text is Snapshot Description. You may edit this by follow steps:
1. on the bar for storyboard panel, right click to show context menu
2. click "Show Description" menu item, the description textbox will show and expand at the bottom of snapshots;
3. double click in description textbox, you can edit it.
Leo
in reply to: LeoWan
Done! Thanks very much!
Cheers
Alan
