Hi there,
I'm trying to access some User definied iProperties of a selected part/assembly within a drawing view. I just get part as a kGenericObject therefore I can't access the properties.
Anyone there who can help me??
Private Sub Button1_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button1.Click
'Test
If _invApp.Documents.Count = 0 Then
MsgBox("Need to open an Assembly document")
Return
End If
If _invApp.ActiveDocument.DocumentType <> DocumentTypeEnum.kDrawingDocumentObject Then
MsgBox("Es muss eine Z-Ableitung aktiv sein.")
Return
End If
Dim drawDoc As DrawingDocument
drawDoc = _invApp.ActiveDocument
If drawDoc.SelectSet.Count = 0 Then
MsgBox("Wähle eine Linie, Baugruppe oder Bauteil")
Return
End If
Dim selSet As SelectSet
selSet = drawDoc.SelectSet
Dim oSelectName As String
If TypeOf selSet.Item(1) Is ComponentOccurrence Then
MsgBox("Test")
Dim oOcc As ComponentOccurrence
oOcc = selSet.Item(1)
Dim oDoc As Document
oDoc = oOcc.Definition.Document
Dim oProp As [Property]
oProp = oDoc.PropertySets.Item("{D5CDD505-2E9C-101B-9397-08002B2CF9AE}").Item("BENENNUNG2")
MsgBox(oProp.Value)
End If
MsgBox("Test2")
End Sub
I hope this will help you .But i done this using VB.net ,So you need to modify this code according to your requirement.
Here you need to select a drawingcurve & that will get the component properties .So that you will get the value of that property.
'Open a assembly drawing before run this & Change properties in custom tab as per your requirement
If inventordoc.DocumentType = Inventor.DocumentTypeEnum.kDrawingDocumentObject Then
Dim odoc As Inventor.Document
odoc = inventorApp.ActiveDocument
Dim oSelectSet As Inventor.SelectSet
oSelectSet = odoc.SelectSet
Dim oDrCurveseg As Inventor.DrawingCurveSegment
oDrCurveseg = inventorApp.CommandManager.Pick(Inventor.SelectionFilterEnum.kDrawingCurveSegmentFilter, "Select a drawingCurve")
oSelectSet.Select(oDrCurveseg)
Dim oCurve As Inventor.DrawingCurve
oCurve = oDrCurveseg.Parent
If TypeOf oCurve.ModelGeometry Is Inventor.EdgeProxy Then
Dim oEdge As Inventor.Edge
oEdge = oCurve.ModelGeometry
Dim oBody As Inventor.SurfaceBody
oBody = oEdge.Parent
Dim oOC As Inventor.ComponentOccurrence
oOC = oBody.Parent
If oOC.DefinitionDocumentType = Inventor.DocumentTypeEnum.kPartDocumentObject Then
odoc = oOC.Definition.Document
Dim oProp As Inventor.Property
oProp = odoc.PropertySets.Item("Inventor User Defined Properties").Item("Height")
Console.WriteLine(oPropSet.Value)
End If
End If
End If
It worked 🙂
But I had to deaktivate oSelectSet.Select (oDrCurveseg)
Thanks a lot 🙂
Dim inventorApp As Inventor.Application
Set inventorApp = GetObject(, "Inventor.Application")
Set odoc = inventorApp.ActiveDocument
If odoc.DocumentType = Inventor.DocumentTypeEnum.kDrawingDocumentObject Then
On Error Resume Next
Set oSelectSet = odoc.SelectSet
Set oDrCurveseg = inventorApp.CommandManager.Pick(Inventor.SelectionFilterEnum.kDrawingCurveSegmentFilter, "Select a drawingCurve")
' oSelectSet.Select (oDrCurveseg)
Set oCurve = oDrCurveseg.Parent
Set oEdge = oCurve.ModelGeometry
Set oBody = oEdge.Parent
Set oOC = oBody.Parent
Set odoc = oOC.Definition.Document
Dim oPropSet As PropertySet
Set oPropSet = odoc.PropertySets.Item("{D5CDD505-2E9C-101B-9397-08002B2CF9AE}")
Dim oProp As Property
' oProp = odoc.PropertySets.Item("{D5CDD505-2E9C-101B-9397-08002B2CF9AE}").Item("BENENNUNG2")
Set oProp = oPropSet.Item("BENENNUNG1")
Dim oString1 As String
Dim oString2 As String
Dim oString3 As String
oString1 = oProp.Value
Set oProp = oPropSet.Item("BENENNUNG2")
oString2 = oProp.Value
Set oProp = oPropSet.Item("BEZEICHNUNG1")
oString3 = oProp.Value
MsgBox ("BENENNUNG1 = " & oString1 & " BENENNUNG2 = " & oString2 & " Bezeichnung1= " & oString3)
End If
End If
End If
You need to add Selection set clear method to deactivate drawingcurve.
Something like this...
oSelectSet.clear( )
End If
End If
End If
