In my parametric model I have 2 parts and 2 subassemblies that change in angle, in a way that my viewcube orientation will change while i dont want it to. Untill now we reset it by hand, but i like it to be automated. (preferably from my top assembly) I found already the code below that works from the specific part and subassembly but i cant get it working from my topassembly. I hope you guys can help me. Thanks in advance.
Sub Main() PartDocument.Activate() Dim partDoc As PartDocument = ThisApplication.ActiveDocument 'gets the activedocument in partdocument form Dim partDef As PartComponentDefinition = partDoc.ComponentDefinition 'gets the part file definition. Dim selectedworkplane As WorkPlane = partDef.WorkPlanes(4) 'gets the XY plane so swap this with whatever your object is SetFrontViewToWorkplane(ThisApplication, partDoc, selectedworkplane) End Sub Public Shared Sub SetFrontViewToWorkplane(ByVal InventorApp As Inventor.Application, ByVal partDoc As PartDocument, ByVal selectedWorkPlane As WorkPlane) partDoc.SelectSet.Clear() partDoc.SelectSet.[Select](selectedWorkPlane) Dim selSet As SelectSet = partDoc.SelectSet Dim LookAt As ControlDefinition = InventorApp.CommandManager.ControlDefinitions("AppLookAtCmd") LookAt.Execute() selSet.Clear() Dim activeView As View = InventorApp.ActiveView activeView.SetCurrentAsFront() End Sub
Solved by b.bosman. Go to Solution.
Solved by Andrii_Humeniuk. Go to Solution.
Hi @b.bosman . This code must be run in the top assembly.
Sub Main()
Dim oDoc As Document = ThisDoc.Document
If Not TypeOf oDoc Is AssemblyDocument Then Exit Sub
Dim AsmDoc As AssemblyDocument = oDoc
Dim oDocs As Documents = ThisApplication.Documents
Dim oVisDocs As DocumentsEnumerator = oDocs.VisibleDocuments
For Each oRefDoc As Document In AsmDoc.AllReferencedDocuments
If TypeOf oRefDoc Is PartDocument Then
If oRefDoc.IsModifiable Then
Dim bVisible As Boolean
For Each oVisDoc As Document In oVisDocs
If oVisDoc Is oPartDoc Then bVisible = True
Next
If bVisible Then
oPartDoc.Activate()
Call SetFrontViewToWorkplane(oRefDoc)
oPartDoc.Save()
Else
Dim oVisDoc As Document = oDocs.Open(oRefDoc.FullDocumentName, True)
Call SetFrontViewToWorkplane(oVisDoc)
oVisDoc.Save()
oVisDoc.Close()
End If
End If
End If
Next
If Not AsmDoc.IsOpenExpress Then AsmDoc.Activate()
End Sub
Public Function SetFrontViewToWorkplane(ByVal oDoc As Document)
Dim XYplane As WorkPlane = oDoc.ComponentDefinition.WorkPlanes(3)
Dim selSet As SelectSet = oDoc.SelectSet
selSet.Clear()
selSet.Select(XYplane)
Dim LookAt As ControlDefinition = ThisApplication.CommandManager.ControlDefinitions("AppLookAtCmd")
LookAt.Execute()
selSet.Clear()
Call ThisApplication.ActiveView.SetCurrentAsFront()
End Function
Andrii Humeniuk - Leading design engineer
LinkedIn | My free Inventor Addin | My Repositories
Did you find this reply helpful ? If so please use the Accept as Solution/Like.
@Andrii_Humeniuk Thanks for your help! The code is doing what i mentioned. But it runs through all my parts (more than 60 parts) while I need it for only 2 parts and 2 subassemblies (Always the same parts en subassemblies). Do you think thats possible?
Of course it is possible, but for the code you need to indicate exactly which components you need. For example, if you need specific components, you can select them by name.
Write the names of your documents in line 7.
Sub Main()
Dim listName As New List(Of String) From {"Name your part1", "Name your part2", "Name your assembly1"}
If listName.Contains(oRefDoc.DisplayName) Then
Next
If bVisible Then
oPartDoc.Activate()
oPartDoc.Save()
Else
oVisDoc.Save()
oVisDoc.Close()
End If
End If
End If
Next
End Sub
selSet.Clear()
LookAt.Execute()
selSet.Clear()
End Function
