Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
Replace components in weldment assembly
3 REPLIES 3
922 Views, 3 Replies
Hello vba-User,
in past I replaced components in Assemblies with this sub:
Sub testReplacePartInAss()
    Call ReplacePartInAss("W:\INVENTOR\T\Part1.ipt", "W:\INVENTOR\T\Part2.ipt")
End Sub
Sub ReplacePartInAss(sInAssFilename As String, sNewFilename As String)
    Dim oApp As Inventor.Application
    Set oApp = ThisApplication
    Dim oOcc As ComponentOccurrence
    Dim oSourceDoc As Document
    Dim oAssDoc As AssemblyDocument
    Set oAssDoc = oApp.ActiveDocument
    For Each oSourceDoc In oAssDoc.ReferencedDocuments
        For Each oOcc In oAssDoc.ComponentDefinition.Occurrences
            If oOcc.ReferencedDocumentDescriptor.FullDocumentName = sInAssFilename Then
                Call oOcc.Replace(sNewFilename, False)
            End If
        Next
    Next
End Sub
But if the assembly is a weldment assembly the line
creates an error '91' that the object is not set.
What has to be changed in this code so that it will work with 'normal' assemblies AND weldment Assemblies too.
Thank for your help,
Stefan
3 REPLIES 3
   if I well remember, while traversing a welded assembly you'll find a "strange" occurrence with a name like "_W..." which inside inventor model browser corresponds to the "Welding" node at the top of the browser.
If this is the case you have only to skip this occurrence because it is really not an occurrence.
adam.nagy
Hi Stefan,
I think you could do something like this:
Sub AvoidWeldmentSpecificOccurrences()
    Dim doc As AssemblyDocument
    Set doc = ThisApplication.ActiveDocument
    Dim occ As ComponentOccurrence
    For Each occ In doc.ComponentDefinition.Occurrences
        If occ.Suppressed Then
            ' A weldment specific occurence cannot be
            ' suppressed I think, so this one is not a
            ' weldment specific occurrence
            ' Also a suppressed component has no Definition
            ' because the document is not loaded, so occ.Definition
            ' would throw an error here
        Else
            ' Here we can check the Definition
            If occ.Definition.Type = kWeldsComponentDefinitionObject Then
                ' This is a weldment specific occurrence
                ' so just ignore it
            End If
        End If
    Next
End Sub
I hope this helps.
Cheers,
Adam Nagy
Autodesk Platform Services
Hi Adam,
yes it works fine - thanks!!! Smiley Very Happy
Now I can complete my function!
Cheers,
Stefan
