Placing Content center component using VBA
11 REPLIES 11
Message 1 of 12
1855 Views, 11 Replies
We are developing a macro for steel structures and we will be very pleased to know about the program to insert or place a content center component in assembly through VBA programming. If there are provisions for changing the object type and changing length in that importing process it will be very helpful.
11 REPLIES 11
Message 2 of 12
philippe.leefsma
Hi
Please take a look first at what's doable in the API Help Files samples, see
Place Content Center Parts API Sample
Replace content center part API Sample
I hope it helps,
Philippe.
Philippe Leefsma
Developer Technical Services
Autodesk Developer Network
Message 3 of 12
I am using autodesk inventor 2009 & 2011... and i dont find any such samples.... is it only there in 2013 package?
Tags (3)
Message 4 of 12
philippe.leefsma
Yes it's been added few releases ago. There was no API access to CC before, sorry for the bad news.
Philippe Leefsma
Message 5 of 12
Thanks for your reply... Which version actually can suit my need... Please suggest.... ortell me  some other autodesk software that can help me...
Tags (1)
Message 6 of 12
philippe.leefsma
Please take a look at the 2013 API Help Files, you can find it on the Inventor Developer Center. The version in which the feature was introduced is indicated at the bottom of each property/method. Some of the CC API was introduced in 2010, there has been incremental additions since then.
Philippe Leefsma
Message 7 of 12
in reply to: philippe.leefsma
Thanks again... Please let me know which version can actually suit my
purpose... Which version has provisions for adding CC through API(VBA
programming), Specifically steel structures like beams, channels and
angles..... and allows me to specify length through program....
Message 8 of 12
Thanks again.... can you please tell me in which version exactly VBA programming can be done for placing CC components like angles, channels and beams by specfying length through program and logics....
Tags (1)
Message 9 of 12
philippe.leefsma
According to Help Files, looks like 2011 can do it...
Philippe Leefsma
Message 10 of 12
thnk u....it helped me a lot...
Message 11 of 12
Hi
Would you please share your solution?
I want to be able to insert a component from content center as custom and promt the user for a "Length" input.
Best regards/
Jozsef
Message 12 of 12
I resolved this issue by creating a sketch and saving it as a part file h
in a specified folder. Then through code i fetched the sketch and extruded
to required length. What i actually needed was a ISMC channel and i
obtained that by above method.
