Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
Howto: close profile
6 REPLIES 6
649 Views, 6 Replies
Could You help me How can I create closed profile in VBA
Suppose this profile includes Line and Spline
See attached code in vb
Later I cannot create Extrude feature because previously
created profile is open (consists of two separate curves)
Could You help me How can I join together points in
profile which belongs to separate curves to get one curve.
I know that this is simple :), but ... I could not find the solution.
Thx for all Your help.
Regards
Dim t As Inventor.TransientGeometry
Set t = ThisApplication.TransientGeometry
Dim c As Inventor.ComponentDefinition
Set c = ThisApplication.ActiveDocument.ComponentDefinition
Dim wpts As Inventor.WorkPoints
Set wpts = c.WorkPoints
Dim wp0 As Inventor.WorkPoint
Set wp0 = wpts.AddFixed(t.CreatePoint(0, 0, 0))
Dim wp1 As Inventor.WorkPoint
Set wp1 = wpts.AddFixed(t.CreatePoint(1, 0, 0))
Dim wp2 As Inventor.WorkPoint
Set wp2 = wpts.AddFixed(t.CreatePoint(0, 1, 0))
wp2.Visible = False
Dim wpls As Inventor.WorkPlanes
Set wpls = c.WorkPlanes
Dim wpl As Inventor.WorkPlane
Set wpl = wpls.AddByThreePoints(wp0, wp1, wp2)
wpl.Visible = False
Dim s As Inventor.PlanarSketch
Set s = c.Sketches.Add(wpl)
Dim oc As ObjectCollection
Set oc = ThisApplication.TransientObjects.CreateObjectCollection
Call oc.Add(t.CreatePoint2d(0, 0))
Call oc.Add(t.CreatePoint2d(1, 0))
Call oc.Add(t.CreatePoint2d(0, 1))
Dim sp As Inventor.SketchSpline
Set sp = s.SketchSplines.Add(oc)
Dim sl As Inventor.SketchLine
Set sl = s.SketchLines.AddByTwoPoints(t.CreatePoint2d(0, 0),
6 REPLIES 6
I haven't tried it with your code, but when you add the line try using the spines
startpoint and endpoint
Something like this maybe?
Set sl = s.SketchLines.AddByTwoPoints(sp.startsketchpoint, sp.endsketchpoing)
Kent
Assistant Moderator
Autodesk Discussion Forum Moderator Program
"jarek" wrote in message
news:F006284CCC9131E23C743FE80B4A9326@in.WebX.maYIadrTaRb...
I think what you want to do is use the .Merge method to combine the
start and end points, closing the curve.
Hi There
I have exactly the same problem. My profiles also conatain curve. How did you solve this problem?
See attached file for my profile.
Thanks in advance
Irfan
Now I have the same problem. Can anybody provide a solution?
Thanks.
You have to add constrains between the start/endpoints...
I had the same issue too, and that solved my problem.
hithere8
Thanks Fred, that worked by adding constraints.
Autodesk Customer Advisory Groups
