I had some parts built up by multiple sweep-features. And i needed the length for these parts.
I found this Being Inventive post from 2011. That rule did most of the work for me. But it is hardcoded for 1 sweep with a specific name.
I tried to make it universal and it looks like I succeeded. So use it, steal it, i don't care. But if you improve upon it or, please let me know.
Disclaimer: I'm not much of an iLogic programmer, I much prefer VBA. Debugging in iLogic sucks.
Sub main
'Set a reference to the active part document
Dim oDoc As PartDocument
oDoc = ThisApplication.ActiveDocument
Dim oDef As PartComponentDefinition
oDef = oDoc.ComponentDefinition
Dim LengthTotal As Double
LengthTotal = 0
'add length of all sweeps
Dim oSweep As SweepFeature
For Each oSweep In oDef.Features.SweepFeatures
Dim oPath As Path
oPath = oSweep.path
LengthTotal = LengthTotal + GetLengthOfSweep(oPath)
Next oSweep
Dim oparams As Parameters
Dim oparam As Parameter
oparams = oDoc.ComponentDefinition.Parameters
Dim exists As Boolean
exists = False
'Find out if parameter exists
Dim paraName As String
paraName = "Length"
For Each oparam In oparams
If oparam.Name = paraName Then exists = True
Next oparam
'Change the value if the parameter exists otherwise add the parameter
If exists Then
oparams.Item(paraName).Value = LengthTotal
Else
oparams.UserParameters.AddByValue(paraName, LengthTotal, 11266)
End If
Call ParaExport(oDef.Parameters, paraName, kZeroDecimalPlacePrecision)
oDoc.Update
End Sub
'get length of a sweep
Private Function GetLengthOfSweep(ByVal oPath As Path) As Double
Dim TotalLength As Double
TotalLength = 0
Dim oCurve As Object
Dim i As Integer
For i = 1 To oPath.Count
oCurve = oPath.Item(i).Curve
Dim oCurveEval As CurveEvaluator
oCurveEval = oCurve.Evaluator
Dim MinParam As Double
Dim MaxParam As Double
Dim length As Double
Call oCurveEval.GetParamExtents(MinParam, MaxParam)
Call oCurveEval.GetLengthAtParam(MinParam, MaxParam, length)
TotalLength = TotalLength + length
Next i
Return TotalLength
End Function
'exporting the parameter, optional
Private Sub ParaExport(ByRef oParas As Parameters, _
ByVal oParaName As String, _
ByVal oDecimalPrecision As CustomPropertyPrecisionEnum)
Dim oPara As Parameter
For Each oPara In oParas
If String.Compare(oPara.name, oParaName) = 0 Then
If Not oPara.ExposedAsProperty = True Then oPara.ExposedAsProperty = True
If Not oPara.CustomPropertyFormat.ShowUnitsString = False Then _
If Not oPara.CustomPropertyFormat.ShowLeadingZeros = True Then _
If Not oPara.CustomPropertyFormat.ShowTrailingZeros = False Then _
If Not oPara.CustomPropertyFormat.Precision = oDecimalPrecision Then _
Dim oComment As String
oComment = "Is determined by by iLogic-rule: 'SweepLength'"
If Not oPara.Comment = oComment Then oPara.Comment = oComment
Exit Sub
End If
Next oPara
End Sub
Solved by mr_ensing. Go to Solution.
Please provide a non-confidential part file to investigate.
Thanks and regards,
It's not that i have a problem. It's just that i'm curious if there is something to improve.
But still, a model is attached.
I don't know if this helps or anything, but here are a couple other similar, but more condensed variations of your code.
This version maintains all the separate Subs & Functions, in case you like that sort of thing.
Sub main
Dim oDoc As PartDocument = ThisApplication.ActiveDocument
Dim oDef As PartComponentDefinition = oDoc.ComponentDefinition
Dim LengthTotal As Double = 0
Dim oPath As Path
For Each oSweep As SweepFeature In oDef.Features.SweepFeatures
oPath = oSweep.Definition.Path
Next
Dim oUParams As UserParameters = oDoc.ComponentDefinition.Parameters.UserParameters
Dim oExists As Boolean = False
Dim oParamName As String = "Length"
For Each oUParam As UserParameter In oUParams
If oUParam.Name = oParamName Then
oUParam.Value = LengthTotal
oExists = True
End If
Next
If oExists = False Then
oUParams.AddByValue(oParamName, LengthTotal, UnitsTypeEnum.kDefaultDisplayLengthUnits)
End If
ParaExport(oDef.Parameters.UserParameters, oParamName, kZeroDecimalPlacePrecision)
oDoc.Update
End Sub
Dim TotalLength As Double = 0
For i As Integer = 1 To oPath.Count
Next
Return TotalLength
End Function
Private Sub ParaExport(ByRef oUParas As UserParameters, ByVal oParaName As String, _
For Each oUPara As UserParameter In oUParas
If oUPara.Name = oParaName Then
oUPara.ExposedAsProperty = True
Dim oCPF As CustomPropertyFormat = oUPara.CustomPropertyFormat
oCPF.PropertyType = CustomPropertyTypeEnum.kNumberPropertyType
oCPF.Precision = oDecimalPrecision
oUPara.Comment = "Is determined by by iLogic-rule: 'SweepLength'"
Exit Sub
End If
Next
End Sub
And here is the even further condensed version, that doesn't bother using Subs & Functions to separate everything out:
Dim oTotalLength As Double = 0
Dim oPath As Path
Dim oLength As Double
oCurveEval.GetLengthAtParam(MinParam, MaxParam, oLength)
oTotalLength = oTotalLength + oLength
Next
Next
Dim oUParam As UserParameter
For Each oUParam In oUParams
oUParam.Value = oTotalLength
oExists = True
End If
Next
oUParam = oUParams.AddByValue(oParamName, oTotalLength, UnitsTypeEnum.kDefaultDisplayLengthUnits)
End If
oUParam.ExposedAsProperty = True
Dim oCPF As CustomPropertyFormat = oUParam.CustomPropertyFormat
oCPF.Precision = CustomPropertyPrecisionEnum.kZeroDecimalPlacePrecision
oUParam.Comment = "Is determined by by iLogic-rule: 'SweepLength'"
RuleParametersOutput()
InventorVb.DocumentUpdate()
I hope this helps.
If this solves your problem, or answers your questions, please click 'Accept As Solution".
Or, if this helps you reach your goal, please click 'LIKES" 👍.
Also, if you're interested, here are a few of the 'Ideas' I'd like to get implemented.
If you agree with any of them, please vote for them.
Inventor 2020 Help | Inventor Forum | Inventor Customization Forum | Inventor Ideas Forum
Wesley Crihfield
As i wrote before, usually i'm writing VBA code, in wich declaring and assigning at once is not possible. That made the code a lot compacter.
I dropped ParaExport function for this use case. But i added the GetPara function and got rid of the Boolean (oExists).
Plus small stuff like this:
'changed to:
LengthTotal = LengthTotal + GetLengthOfSweep(oSweep.Definition.Path)
My current code:
Sub Main
LengthTotal = LengthTotal + GetLengthOfSweep(oSweep.path)
Next oSweep
'get(or create) parameter
Dim oPara As Parameter = GetPara(oDoc.ComponentDefinition.Parameters, "SweepLength")
'assign value and comment
oPara.Value = LengthTotal
Dim oComment As String = "Determined by iLogic-rule: 'SweepLength'"
oDoc.Update
End Sub
Next i
Return TotalLength
End Function
Private Function GetPara(ByRef oParas As Parameters, ByVal paraName As String) As Parameter
If oPara.Name = paraName Then Return oPara
Next oPara
Return oParas.UserParameters.AddByValue(paraName, 0, 11266)
End Function
I changed one more thing:
'from
'to:
Dim oDoc As PartDocument = ThisDoc.Document
I would like to display the above iLogic results to one decimal place.
I would like to add a unit to the end of the result.
