Turn off LINK by default to insert images
Dear Dev,
When you insert an image in Inventor (ie to use as a decal) the LINK option is turned on by default. This looks nice, but can create a lot of issues lateron (especially when using Vault). So I think it would be better to turn it of by default, because if you forget you'll get in trouble lateron and this is very annoying...
14 Comments
fsanchou
Most users do not need to update the pictures after having inserted in the sketch.
mikeh2
We've link files so that if we need to update the image we can.  We use images sometimes for assembly clarity like house routing.
We prefer it linked.  Perhaps make it an Application option?
kwilson_design
i gave kudos but would want this in the Application Option somewhere.
We link our files as well. It's an annoyance having them linked if you're a vault user but it is easier to maintain file relationships if they are linked.
jtylerbc
I agree with making it an application option to set the default.  I personally would probably turn default linking off, but can see where companies that want more control over the images would want it the other way.
steve.west
I agree. Same issue occurs if you use an image file in your title block.
fsanchou
douthett
I agree with this idea. Too often we have to redo our work because we forgot to uncheck the link box. It wouldn't be as much of a problem if the 'Break Link' command wasn't broken
I agree!
dan_szymanski
Status changed to: Gathering Support
Hello fsanchou,
Although your Idea was posted first (on 9/12/2013) another duplicate Idea already has over 60 kudos applied to it.  As such I am going to mark this Idea as Duplicate and keep the other as the Master.  The Master Idea can be found here:
http://forums.autodesk.com/t5/inventor-ideastation/turn-off-link-by-default-to-insert-images/idi-p/5...
Please be sure to cast your kudo to it as to not split votes.  Thanks for understanding.  -Dan
s.wile
I can think of few reasons to link images to a sketch. Constantly I deal with companies with years of legacy files tied to several image files that have long since been lost.
Currently I am working on a project that will involve many images to reference splines over. I do not want any of the images linked yet I keep linking them by mistake.
The Link check box should not be check by default. Most users are not even aware they are creating a dependancy when bringing in reference images.
Tags (3)
dan_szymanski
Status changed to: Accepted
Accepted idea [US-51799]. Thanks!
dan_szymanski
Hello, this Idea has already been submitted here:
Please cast your kudo to the Master Idea as to not split votes.  Thanks! -Dan
dan_szymanski
This idea has been implemented within Autodesk Inventor 2017. Special thanks to everyone who cast a vote for it.
jason_mcdonald
Earlier this year I upgraded to IV2019 and was dismayed that my circuit board image files (that I'm constantly updating during the product development cycle) were no longer update-able and were not checking into Vault like they used to.  It took me a while to find this thread and subsequently the "Link" check box.  Now I have to try to remember to check the Link box every time I make a PCB decal.
Question:   Is there a setting somewhere that toggles the default setting somewhere?  Or could the Link checkbox just default to it's last-used status?
