T&P conduit part number inherit from CC
In Inventor 2016 there is a new function that you can use to inherit the part number from the CC. The part number in the BOM is however still always based on the length of a specific pipe segment. We want full control over the part number, we really want to INHERIT the part number from the CC so all our pipes of the same diameter & schedule will roll up in the BOM.
This is the forum topic where the functionality is discussed: http://forums.autodesk.com/t5/inventor-general-discussion/t-amp-p-conduit-part-number-settings-2016/...
3 Comments
tasnad.peter_pureco
Under my CC Family table I use the an equation like this: "=Ø<OD> x <SN> - <PL> - <MATERIAL> - <MASS>". It should work under T&P with the inherit the Part Number from CC is enabled (working function, not just the current values!). Adding the <PL> at the end of the part number automatically is not a good idea, we need full, customize able control from CC Family Table.
inv.ideareview
Thanks for sharing your Idea. We use this forum to guide product development and help users in the best way we can, based on voting. We occasionally merge Ideas or archive old ones to keep the forum working properly - it ensures there is room for people to review new Ideas and that the most relevant and meaningful ones can gain votes. We’re archiving this Idea because it's been on the board for well over a year and hasn't received many votes from the community. If you want to raise it again and try to gain more support, you're welcome to do so. We’ve found that pictures and mock-ups can help get concepts across and win more votes from other users. If you have questions or see a connection between this Idea and others, let us know. - Inventor product team (Inv.idea review)
inv.ideareview
Status changed to: Archived
