Standard Tap Depth
Standard Tap Depth
I would like to have Tapped Holes follow each Standard for the Tap Depth rather than relying upon user knowledge.
12 Comments
Rory_M
I'd like this too, as long as the standard tap depth is an option that is:
a) Easily overridden and
b) User editable (maybe in the thread spreadsheet)
cmcconnell
Yes - I agree. I would like it to default to thd depth + 2*pitch
Mark_Wigan
i like the idea.
i would also like to see some of the user input boxes positioned better in the dialogue box... they do not seem to flow logically and are not all positioned relative to the dimension that they relate to.
karthur1
Something I asked for years ago.  I would like to see the depth controlled by an excel sheet (like the Clearance.xls) so everyone can edit it to suite their own "standards".
I would like to see this implemented too. This should not be a big alteration I think, and would provide more standardisation.
BryanKelley
This project [US5183] [US9040 ]is under review by the development team.
dan_szymanski
Status changed to: Accepted
Accepted idea [US5183]. Thanks!
dan_szymanski
This idea has been implemented within Autodesk Inventor 2015. Special thanks to everyone who cast your Kudo for it. Enhancements have been made within the Modeling environments, when creating holes, to default to the thread and hole depth values specified within the updated thread.xls file. Please be sure to check this out in Autodesk Inventor 2015. Thanks!
blandb
By default to have the tap drill depth automatically set for blind tapped holes based on the thread size and thread depth. This value could be modified in the thread table excel file if needed to be changed for your companies standards. But would keep new employees or individuals that don't know better to make the tap drill depth too shallow. Would keep things consistant across the board. This would only apply if "Full Depth" is not checked incase that is needed.
Tags (2)
DRoam
@blandb, this is a duplicate of another idea, which has been Implemented: Standard Tap Depth.
Unfortunately, it was implemented such that the hole depth and thread depth are changed automatically (and without notifying the user) if the tap diameter is changed, which is very likely to cause undetected design errors. You can vote for using the standard depth to be an option (rather than automatic) here: Thread hole standard depth defaults (currently 1 vote).
DRoam
@Rory_M and anyone else who's interested, you can vote for this to be an option (rather than an automatic change) here: Thread hole standard depth defaults.
It's great that we have these standard depths at our disposal, but it's very dangerous (and annoying) that the hole depth and thread depth are changed automatically (and without notifying the user) when the tap diameter is changed. At best this is annoying because we have to change it back; at worst, it can result in a costly design error if we don't happen to notice that Inventor changed them. This should be a checkbox option (Use Standard Depths) rather than a silent, automatic change.
You can edit the table to change the hole depths to a standard your shop uses. I attached a picture of where you change. If anyone is still looking to be able to change this it isn't super clear in the default table I edited ours to make it clearer.
