Show values in tables for dimensions created by a formula
When I add a parameter to a table on a 2D drawing it displays the formula used to create that parameter.  I want to be able to show the value in the table.  To me this seems like an obvious requirement and I'm confused as to why it doesn't seem to be possible.
The people working from the drawing shouldn't have to start calculating dimensions from a formula, and I don't want to have to create excel spreadsheets for every drawing table.
7 Comments
...instead of returning the equation and it's called parameters in text format.  This hamstrings a great feature and causes me pain.
Tags (5)
This should just be a selection box on table placement, do I want equations or values displayed.
Great suggestion Dylan.
inv.ideareview
Thanks for sharing your Idea. We use this forum to guide product development and help users in the best way we can based on voting. We occasionally merge Ideas or archive old ones to keep the forum working properly - it ensures there is room for people to review new Ideas and that the most relevant and meaningful ones can gain votes. We’re archiving this Idea because it's been on the board for well over a year and hasn't received many votes from the community. If you want to raise it again and try to gain more support, you're welcome to do so. We’ve found that pictures and mock-ups can help get concepts across and win more votes from other users. If you have questions or see a connection between this Idea and others, let us know. - Inventor product team (Inv.idea review)
inv.ideareview
Status changed to: Archived
jwheatleyCT
When using spreadsheets to create parameters that link across multiple ipart or iassembly files, drawing creators should be able to have the ability to, after creating an ipart table, choose the parameter that is text and not a number, and change the representation of that text to it's actual value in the iassembly/ipart. Not being able to do this renders my ability to utilize spreadsheets obsolete since there is no way to show them expressly as numerical values in a drawing.
alexander.hendrix
This feature is really missed to show the operators on the shop floor the actual value instead of an equation that they still have to compute in their head, opening up for mistakes and misunderstandings. There should be a toggle for each column what to show in the table: Equation or value.
Yijiang.Cai
Many thanks for posting the idea, and tracked as [INVGEN-87848]
