Hi!
Does anyone know if it is possible to use a sketch to write text on sheet metal? On regular solids the emboss feature is sufficient, but I can't seem to find info on how to write on sheet metal...
Thank you!
Michael
Solved by -niels-. Go to Solution.
You have acces to the "regular solid" features on the "3D model" tab, emboss is available there.
Keep in mind that these features will show on the flat pattern, so you might have to make some edits there.
Niels van der Veer
Inventor professional user & 3DS Max enthusiast
Vault professional user/manager
The Netherlands
