Hi
I was wondering if there is a way to change the appearance of a face in a weldment assembly environment. I have a weldment which in the machining process a part of weld bead as well as a portion of one of the componets is machined down (spot faced) and I need to change the apprearance of those face to polished, but it doesnt let me do that? is it me, or its not possible?
Solved by blair. Go to Solution.
Currently all the welds beads will change. Select the weld bead (any weld bead) and then change the appearance from the Appearance drop-down menu and unfortunately all the weld beads in the assembly will change. Short of Photo-Shopping a picture I don't think it can be done
yeah, I thought so, cause I tried different ways and unfortunately I couldnt, if it was in a part environment, it was easy as you can change the appearance of any operation generated face through properties in the right click menu.
maybe a good one to add to wish list for future versions.
Thank you
Ali
Inventor IdeaStation is the place to do that.
Sam B
Inventor 2012 Certified Professional
Please click "Accept as Solution" if this response answers your question.
Inventor Professional 2013 SP1.1 Update 1
Windows XP Pro 32-bit, SP3
HP EliteBook 8730w; 4 GB RAM; Core™ 2 Duo T9400 2.53 GHz; Quadro FX2700M
SpaceExplorer/SpaceNavigator NB, driver 3.7.18
still waiting for a foreshortened radius dimensioning tool in Drawing Manager
