Inventor Forum
Invertor 2014 Purge styles
10 REPLIES 10
Message 1 of 11
petrxn
1055 Views, 10 Replies
Hi, it seems that there is bug with purge styles from assembly and child documents. I select checkbox "Purge Styles from all Child Documents" then push button "Yes to All" and "OK", dialog very quickly close, and styles are not purged.
Is this known issue? Can be this tested by somebody else? I use Inv 2014SP1 (build 222).
Petr
10 REPLIES 10
Message 2 of 11
-niels-
in reply to: petrxn
I'm seeing the same behavior, but only with the child documents.
Any excess styles in the main assembly are purged, but the childs don't follow suit.
Niels van der Veer
Inventor professional user & 3DS Max enthusiast
Vault professional user/manager
The Netherlands
Message 3 of 11
petrxn
in reply to: -niels-
Thank you, now question to Autodesk, why? And when this will be corrected?
Petr
Message 4 of 11
akhidrosyidi
in reply to: petrxn
hi autodesk!
please, your comment about this problem.
daily works with :
Autodesk Inventor Profesional 2014.
AutoCAD Mechanical 2014.
Autodesk Vault Profesional 2014.
Message 5 of 11
mcgyvr
in reply to: akhidrosyidi
@Anonymous wrote:
hi autodesk!
I just reported it again just incase..
Message 6 of 11
johnsonshiue
in reply to: petrxn
Hi! This is indeed a known issue on R2014. It has been corrected on the internal build targeting as SP2 for R2014.
Thanks!
Software Test Engineer
Message 7 of 11
akhidrosyidi
in reply to: johnsonshiue
hi john, thanks for your respon,
we will wait new SP for R2014.
btw, is there any script ( in vba ) to handle this jobs?
because i have an assembly with hundred part need to be purges.
daily works with :
Message 8 of 11
You can update the child documents in the assembly and save, then use batch purge to purge everything.
Message 9 of 11
This still appears to be the case in IV2015 SP2 Update1 - the child styles wont purge. Can anyone verify the behaviour in IV2016 please?
Cheers,
--Rob
Inventor 2024.2
Message 10 of 11
mcgyvr
in reply to: RobSinglehurst
I haven't noticed any problems with purging styles in 2016..
Message 11 of 11
RobSinglehurst
in reply to: mcgyvr
I think this may have re-appeared with either SP2 or Update1 for SP2. Is there anyone else using IV2015 that can't purge child styles when in a top level assembly?
Cheers,
--Rob
Inventor 2024.2
