While working with an Inventor 2013 *.idw some of the dimension lines, extension lines, and learders became invisible, even though you can still see the dimension values and even the arrow heads of the no-show dimensions. Even when printed, the same lines are not there. 2013 Glitch??? And when is the first HotFix coming out??
Solved by bobvdd. Go to Solution.
Having the same problem, and understand why...
However when drawings are re-opened the text boxes are resizing and re-clipping this is a major nuisance
Thank you, thank you. I was losing time working with our 12 year old drawing. This dimension obscuring behavior was not seen in the 2004 and 2010 version we had used. The general note text box has been large without trouble. After doing some edits, using sketch, the drawing updated to the new behavior.
