Hi
Message: Error 1402. Could not open key: Hkey_Local_Machine\\RobotDirectories. Verify you have sufficient access to that key, or contact your support personnel.
I cant find "robotDirectories", I try change the registry key but it's still the same.
I have WinVistaSP2 32-bit, Inventor 2011 ,
What i should do?
your OS is becoming corrupt
my suggestion is to reformat
DarrenP
Try this, it worked for me, although I did not set the owner, I gave the local administrator full access to the keys and installed as the local administrator:
....remember to backup your registry first.
