Hi guys,
What do you think you be the right way to make a surface rough and uneven, as in the picture below? Or should it be done at some later stage?
Thanks.
Solved by -niels-. Go to Solution.
I'd add a texture with a bumpmap to it, that would be the easiest way in my opinion.
Niels van der Veer
Inventor professional user & 3DS Max enthusiast
Vault professional user/manager
The Netherlands
Thanks Niels! Would adding a bumpmap work only visualy in Inventor, or would it also be on the real part, when made with SLA ?
It would only be cosmetic.
I would post process the RP model to get the texture.
If you really want an actual surface, you might do something like in the file i attached.
This is not the best example, but i just made it really fast to give you an idea.
Hope it is of some use.
Niels van der Veer
The Netherlands
