Hi Forum
I have two problems with a IDW drawing.
Most of my views have been crosed over by a red line in the Model browser window (se attachment)
What does this red line meen?
Also, all the views with the red line have been set to Raster View Only. I can untick it without problems, but when I click OK and reopen the dialog the checkmark is back on.
How come inventor turns this mark on by itself?
Regards Rasmus
Solved by -niels-. Go to Solution.
Niels van der Veer
Inventor professional user & 3DS Max enthusiast
Vault professional user/manager
The Netherlands
Hi Niels
Thanks.
As far as I can see it should be up to date. I have tryed to open both the ,ipt file and the assambly in witch it is used and non of those seems to be complaining about anything not being up to date.
Also the view on sheet one does not have any problems. and all the view reference to the same part.
I havent specified to use raster view anywhere (at least not what I'm aware of).
Regards Rasmus
Niels van der Veer
The Netherlands
Niels van der Veer
The Netherlands
Hi Niels
I can't seem to finde anywhere to click "make precise"
I tryed to send you a private message, but I can't attach files to private messages.
Can you send me your email?
/Rasmus
"make view precise" should be here:
If the view is already "precise" then the same line will say "make view raster".
Niels van der Veer
The Netherlands
Hi Niels
The view on sheet one (the one that works), there I can finde the "Make View Precise".
But It's not there in the other ones...
Regards Rasmus
Niels van der Veer
The Netherlands
Hi Niels
Now I started a new drawing with a nother part file.
And all of a sudden I got red lightning on all sheets. I hit update and problem solved...
Many thanks for spending time on me and my problems.
Regards Rasmus
Rasmus,
Can you please confirm that you have Autodesk Inventor 2014 Service Pack 1 installed:
http://usa.autodesk.com/getdoc/id=DL22322619
If you do have SP1 or it did not resolve your issue, can you please ZIP up a Pack and Go of your IDW and send it to me to take a look at. If the ZIP file is too large to be sent through a private message, please let me know and I may be able to contact you outside of the forum.
Thank you.
Luke,
Welcome to the forum.
I think that we will need to have you do a Pack and Go on your IDW/DWG so that we can take a look at it.
Thank you.
The diagonal red bar (raster state) on the drawing tree was my problem of this day and I solve it.
It happened with no reason on all my drawing sheets. I wasn't able to make bend mark on my unfolded part.
I found, it was because i was running out of memory (RAM) with my computer.
I just closed heavy apps, and restart Inventor. All the red bar disappered.
Hope it will help the ones who still didn't fix their issues.
Exactly as above, I had the red bar across all views, which would never finish 'updating' when exporting a DXF. Closed and reopened Inventor, and it's working fine.
