It should open (hopefully)
R7 files (even from the beta I believe) can open In R6 - I could be wrong
though where the beta is concerned but obviously the full version is
backwards compatible.
Basically, I did at part level what you probably did at assy level (but assy
level is a lot quicker!)
I created a coil of 1 revolution and circular patterned it as a feature to
create the bent spring. I assume you used a circular assy pattern
Hope this makes sense (It's Friday night in the UK and I've been drinking!)
Rory
(who uses brackets)(too much)
"Bill Bogan" wrote in message
news:2701E9A0D400CA5768CA1CBD1C4E27F9@in.WebX.maYIadrTaRb...
> I probably can't open it as I am running vanilla 6.0.2
> Bill Bogan
> "Rory" wrote in message
> news:04C8632B669385BF55035A13DDB60A1D@in.WebX.maYIadrTaRb...
> > My file is attached to the same post that has the image.
> > But I'm not sure how Outlook Express handles multiple attachments so
I'll
> > post it as a zip file under the name "Slinky part"
> > Be warned, it was done in IV7 beta as it's the only software I've got on
> my
> > home PC.
> > Rory
> > news:2734F01DA22CBDFA7CFC84F91D45DAE8@in.WebX.maYIadrTaRb...
> > > I went on a vanity trip for one moment and thought you wanted the
> > assembly.
> > > So it's there in the same post.
> > > Bill Bogan
> > > B2 Design
> > > "Sean Dotson" wrote in message
> > > news:71F5E0D8CD5034017E805438D6E931C1@in.WebX.maYIadrTaRb...
> > > > Hey! Cool... How'd you do that?
> > > > Can you post the file?
> > > > Sean Dotson, PE
> > > > http://www.sdotson.com
> > > > Check the Inventor FAQ for most common questions
> > > > www.sdotson.com/faq.html
> > > > news:013E50D8D520FB65A0276FE6E53E6120@in.WebX.maYIadrTaRb...
> > > > > Check out CF.......
> > > > > All done in Inventor, but it doesn't touch at both ends - To do
that
> > I'd
> > > > > have to leave it computing all night, and have a processor the
size
> of
> > a
> > > > > small village and about 20 Gig of Ram.
> > > > > It's not quite a slinky, but as bendy springs go, it's a good one!
> > > > > Rory
