Inventor Forum
Anyone ever attempt to do a slinky?
26 REPLIES 26
Message 1 of 27
296 Views, 26 Replies
Take the two ends of a slinky and hold them together.
Now model that. Anyone ever try to do that?
Bill Bogan
B2 Design
26 REPLIES 26
Message 2 of 27
That's a non linear coil... I don't think IV can do that. Of course I'll be
trying it now..
If we could coil along a path it would be possible I think...
Sean Dotson, PE
http://www.sdotson.com
Check the Inventor FAQ for most common questions
www.sdotson.com/faq.html
"Bill Bogan" wrote in message
news:F6C30FDEFC746673D8A2D22147F4D898@in.WebX.maYIadrTaRb...
> Bill Bogan
> B2 Design
Message 3 of 27
I think making a slinky in R6 is "stretching" it a little, don't you? Can
you tell it's "spring" time?...sorry I posted this on the "rebound"
> Bill Bogan
> B2 Design
Message 4 of 27
lol !
"Albert Allen" wrote in message
news:52174DD712C03FE3D8F97F3CEA395A0A@in.WebX.maYIadrTaRb...
> > Bill Bogan
> > B2 Design
Message 5 of 27
Come on Bill - You worked on Inventor long enough! You know it can't..
Maybe R8 will 😉
But I bet MDT can! (In fact I know it can, one of the first things I did on
MDT 2 was a helix down a helical path using surfaces)
Rory
(If I was at work now I'd have modelled it and posted it)
> Bill Bogan
> B2 Design
Message 6 of 27
I think Laurence did one with a circler cross section awhile ago - did a
search, can't remember which group its in. Maybe he will chime in...
Cory McConnell
BJ pipeline Inspection
Message 7 of 27
Check out CF.......
All done in Inventor, but it doesn't touch at both ends - To do that I'd
have to leave it computing all night, and have a processor the size of a
small village and about 20 Gig of Ram.
It's not quite a slinky, but as bendy springs go, it's a good one!
Rory
Message 8 of 27
See CF - Spring Slinky
I cheated - its an assembly.
Bill Bogan
"Rory" wrote in message
news:013E50D8D520FB65A0276FE6E53E6120@in.WebX.maYIadrTaRb...
> Check out CF.......
> Rory
Message 9 of 27
news:D3BFAA807A1A9FFA666BCD869B9DCF36@in.WebX.maYIadrTaRb...
Mine isn't 😉
Rory
Message 10 of 27
Hey! Cool... How'd you do that?
Can you post the file?
Sean Dotson, PE
> Check out CF.......
> Rory
Message 11 of 27
I don't see Rory's file in CF - what's the subject I'm looking for.
I assume Sean you were asking about Rory's file and not mine.
Bill Bogan
"Sean Dotson" wrote in message
news:71F5E0D8CD5034017E805438D6E931C1@in.WebX.maYIadrTaRb...
> Sean Dotson, PE
> > Check out CF.......
> > Rory
Message 12 of 27
I went on a vanity trip for one moment and thought you wanted the assembly.
So it's there in the same post.
Bill Bogan
B2 Design
> Sean Dotson, PE
> > Check out CF.......
> > Rory
Message 13 of 27
Theres a new CF just for us IV users now, its in there
NTTP Inventor CF (Customer Files):
news://discussion.autodesk.com/autodesk.inventor.customer-files
news:0A5CD4EA0A9B2D733264B15564A14875@in.WebX.maYIadrTaRb...
> Bill Bogan
Message 14 of 27
Thanks Paul, I obviously missed that announcement.
Bill Bogan
"Paul Houlker" <666paulh@rimex.com666> wrote in message
news:385A2F506F96ED08A8ABFE072142B903@in.WebX.maYIadrTaRb...
> > Bill Bogan
Message 15 of 27
My file is attached to the same post that has the image.
But I'm not sure how Outlook Express handles multiple attachments so I'll
post it as a zip file under the name "Slinky part"
Be warned, it was done in IV7 beta as it's the only software I've got on my
home PC.
Rory
news:2734F01DA22CBDFA7CFC84F91D45DAE8@in.WebX.maYIadrTaRb...
assembly.
> Bill Bogan
> B2 Design
> > Sean Dotson, PE
> > > Check out CF.......
I'd
a
> > > Rory
Message 16 of 27
Yours are now in Inventor.customerfiles also 8^)
Kent
Assistant Moderator
Autodesk Discussion Forum Moderator Program
news:5FD1C46C718683F97AE70B9794684E68@in.WebX.maYIadrTaRb...
> Bill Bogan
Message 17 of 27
I probably can't open it as I am running vanilla 6.0.2
Bill Bogan
news:04C8632B669385BF55035A13DDB60A1D@in.WebX.maYIadrTaRb...
my
> home PC.
> Rory
> assembly.
> > Bill Bogan
> > B2 Design
> > > Sean Dotson, PE
> > > > Check out CF.......
> I'd
of
> a
> > > > Rory
Message 18 of 27
It should open (hopefully)
R7 files (even from the beta I believe) can open In R6 - I could be wrong
though where the beta is concerned but obviously the full version is
backwards compatible.
Basically, I did at part level what you probably did at assy level (but assy
level is a lot quicker!)
I created a coil of 1 revolution and circular patterned it as a feature to
create the bent spring. I assume you used a circular assy pattern
Hope this makes sense (It's Friday night in the UK and I've been drinking!)
Rory
(who uses brackets)(too much)
news:2701E9A0D400CA5768CA1CBD1C4E27F9@in.WebX.maYIadrTaRb...
> Bill Bogan
I'll
> my
> > home PC.
> > Rory
> > assembly.
> > > Bill Bogan
> > > B2 Design
> > > > Sean Dotson, PE
> > > > > Check out CF.......
that
> > I'd
size
> of
> > a
> > > > > Rory
Message 19 of 27
Boy when you drop out you REALLY drop out don't you 8^))
R7 files can (should) be able to be opened in R6.
Kent
Assistant Moderator
> Bill Bogan
Message 20 of 27
ROFLAO
"Kent Keller" wrote in message
news:48DD5D8631C05BF7C82ED8BCD09F5AD4@in.WebX.maYIadrTaRb...
> Kent
> Assistant Moderator
> > Bill Bogan
