While I was running Inventor 2013 with Update 2 and SP1 Beta installed, I recreated all my custom materials/appearances. After this all thumbnails were ok and I was finally done with this annoying bug. So I thought.....
When SP1 was released, I un-installed SP1 Beta and installed the release version (about 2 weeks ago). This morning I noticed that my thumbnails were all messed up again. I'm not sure if this was also the case just after I installed SP1, I just noticed it this morning.
I know there are still problems with SP1, so I un-installed it and went back to update 2. I even restored a backup of the material library (although it didn't change according to the 'modified' date in windows explorer). But still no thumbnails..... I re-installed SP1 beta, but this also didn't help.
I'm now back at SP1 (build 170) and I'm not sure what to do now. Is this still a known bug? will this be solved in the final release version of SP1? How will I know that when I update the material library again my thumbnails will remain? I'm getting a bit tired of doing the same thing over and over again....
Anyone have the same problems? Or can someone give me advise on what to do?
Daniël Reesing
IV2013 Pro SP1 (build 170)
You will have to wait for updated sp1 for this one.
I am also waiting, so that i can finally manage all the libraries and thumbnails.
There is also official notice from autodesk about that, but I can't find it right now.
Greg
Then why couldn't I get it to work again when I moved back to update 2 and restored a backup of my material library?
This is all very frustrating....
Daniël
Daniël,
Would you be willing to share your library with us so we can look at the problem closer? You can post it or e-mail it to me directly.
Daniël,
I am very sorry for the trouble you have gone through. Tom forwarded me the Material Library you are using. Indeed, I have verified the problem. We are still in the middle of investigating the issue. In the meantime, I suggest you make a copy of the existing library as a backup and avoid editing the Materials and Appearances for now.
Do you remember when you notice the thumbnails are missing? Are you able to turn a style with thumnail to a style with thumbnail missing?
Thank you!
Hi Johnson,
After I recreated the material library with update 2 and SP1beta installed I had no problems, the thumbnails were fine. I noticed they were gone again about 2 weeks after I've installed the first release of SP1 (the one thats pulled now). But that was the point that I noticed, so it could well be that the problem was already present before I installed the first release of SP1. I can't really remember.
When I noticed it, all my custom materials/appearances had lost their thumbnail. So there is no custom style left to try to turn into a style without thumbnail. I restored a backup of the material library from about a week before I installed SP1 (when I was running SP1 beta). But I still didn't have any thumbnails. I will see if I can find a backup of the library from right after I recreated it.
I'm currently running the RC of SP1.1, I will wait untill the final version will be released and then I will fix my library. Hopefully it will remain this time 🙂
Thanks for all the help.
Daniël
Daniel,
Just curious, is the thumbnail you are missing this one?
I get a preview of the appearance for the local appearances, but just not the thumbnails for my custom appearances that I have put in my Library. I'm using SP1.1 also.
Yes, this is what I mean.
When you copy the styles locally and then save them back to the library the thumbnails should be fixed. I already did that when I had SP1 beta installed. But for some reason I have the same problem again.
I everything is still on track then today the final SP1.1 will be released. When I have installed it I will once again fix my library and hope that this time the thumbnails will remain.
Daniël
I'm afraid I don't have much of an update currently. We are still working to identify what has caused this.
So I have SP1.1 installed now and I wanted to fix my thumbnails again. When I copy an appearance to the document the thumbnails displays in the appearance browser (see image).
When I copy the appearance back to the library, it seems to be working and the thumbnail now also displays correctly in the library (see image). So far so good....
When I then look at the appearance selection drop-down menu in the main window of Inventor, there is still no thumbnail there (see image).
So I restart Inventor to see if that has any effect. But after the restart all seems to be screwed-up again, and the thumnail in the library is lost again (see image).
I've tried completely removing the appearance from the library, so only having it in the local document. It does seems to work then and I even have the thumbnail in the drop-down list. But when I restart Inventor that drop-down list thumnail is gone again. The strange thing is that when I open and close the appearance browser (without changing anything) the drop-down thumnail is there again! That is until I restart Inventor.....
Anyone else still having problems with the material/appearance library?
I also have another problem with the units of the physical material properties, see this thread
Best regards,
Daniël
I'm close to a nervous breakdown from this new Material Library concept. I don't know what i'm doing wrong but i've tried everything.
Above you can find a small video of my attempt in to making a new custom part.
Maybe a should clarify what i'm "trying" to do ... i want to add in my custom library both Physical and Apperance asset of a Custom Material.
In this case i start from Iron Cast and create 2 ones : GG 20 and GG 25 both with their own unique Physical and Appearance Asset (For GG 20 this should be "GG 20 - App" and "GG 20 - Phy")
Please comment on what i am doing wrong ... *sigh*
http://www.screencast.com/users/QBiXX/folders/Default/media/c89da678-4680-4ea7-8c7e-62177e48b0c7
I hope this link works then 🙂
Video works now, thnx.
First, make sure you have SP1.1 installed!!
I noticed you already created library, but it's empty. Why not try to create it from scratch in inventor again?
Then, when you copied materials, what did you do with generic material? Just leave it as it is. You copied new materials to library, that's it. What stays in .ipt part, doesn't matter, leave it.
All you have to do, is assign material to .ipt, duplicate it, edit it, and right click, and add it to your library. Then, close down inventor, navigate to your library file, right click, mark it as read only in windows, then open any part again and test if your library works(should be locked and read only now).
But i'm not sure where did properties for iron (1) go...it should be right in you custom library with GG 20.
Defenitely you have some wierd things going on.
Maybe try this:
When you add material to document, duplicate it, then rename it. After that, edit it, and rename assest also!
Then add edited material to your (create a new one!) library. You can save document (remember, create one empty .ipt just for editing your library!). And close down open document.
Then navigate to library file in windows, mark it as read only, then open your library ipt again, and check out your library.
There's more information here:
http://wikihelp.autodesk.com/Inventor/enu/2013/Help/1310-Autodesk1310/1364-Fundamen1364/1443-Materia...
If nothing works, not even sp1.1, then you should reconsider to reinstall inventor completely. Or if somebody else have better idea.
Greg
So i did some more testing.
We use network project file, that actually works quite ok. And so, libraries work ok, and everything else.
But then i created new project file, and tried to add/edit libraries, and just got the same problems. Can't add library to the project file, and just got all of the problems you have. Inventor won't read not even inventor library. So it looks like new Inventor is very allergic to project files (why?!). But what's wrong i just don't know and can't figure it out. I need new project file, but now i know i can't use it, because i can't add my custom library!
Rubbish!!!
@Anonymous wrote:.... Can't add library to the project file, and just got all of the problems you have. Inventor won't read not even inventor library....
I dont have a problem with it reading the Inventor Library, but sometimes it wont read my custom library. I have tried closing and restarting Inventor after I change projects, but it still wont read it. If I hover over the name, the path is correct. As a temporary fix, I can RMB and chose "Locate Library" and pick it again it it works until I change projects again. Is this what you are seeing?
Why can't you add a library to your project? Can you give some details?
Kirk A.
Windows 7 x64 -12 GB Ram
@Anonymous i7-930 @ 3.60ghz
nVidia GTS 250 -1GB (Driver 301.42)
INV Pro R2013, SP1.1
Vault Basic 2013
So, our main (network) project file is somehow working ok!
But if i try to create new project file (for local use only), then things go wrong (the same with new network project file).
As in your picture, i also have autodesk appearance library, but inventor won't load inventor material library, even if it is added to the project file. And of course, i can't add my custom library. It's just saying there's no materials available. Quite weird, because i was able to add it to appearance libraries under projects (it's not working in inventor).
And then, if i close my .ipt file, which I use for editing material libray, and reopen it, then i can see both inventor and custom library, but with that yellow sign(as on your picture). Path and name are correct, but inventor won't load it. I tried RMB-locate, but still didn't work. Funny thing is, my custom library is not added to the project file under projects at all! It somehow just stays in inventor, but not in the project file.
So i think there's a lot of problems with project files using libraries, since our main project file really works ok, and libraries also! (Have to investigate what's making our main project file to work). It's not good that i can't simply create new project files for local use, that would work with libraries.
Am i doing anything wrong, or is it just buggy software again? It's all the same as for our main project file ...
Hi Tom
is ther any Solution for this thumbnail problem?
I still have this is issue in Inventor 2014 SP1 Update3 now.
Steps to test
working with original Inventor Material Library in original location (C:\Users\Public\Documents\Autodesk\Inventor 2013\Design Data\Materials\)
open the appearance browser with a part file
make a new appearance not a duplicate
save back to inventorMaterial Library
all is fine thumbnail is there
reboot Inventor look into material library
thumbnail is greyed out
double click to cache into document the thumbnail is there in the local cache but not in the library
Hi Michael,
I am following upon the thumbnail issue which you asked Tom.
I tried the workflow you mentioned but failed to duplicate the issue. Thumbnail is always there in library for me(both in 2013 and 2014).
For more investigation can you provide following information?
Thank you,
Maulik Patel
