• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Valued Contributor
    Accepted Solution
    2013 Material physical properties - units
    450 Views, 4 Replies
    10-19-2012 12:03 AM
    Hi there,
    I've just noticed that when I view/edit the physical properties of a material, the units are not in metric/iso format. I'm certain that a couple of months ago when I added some materials to the library, they were in metric/iso format. Is this a setting somewhere? or has this changed since SP1.1?
    Can someone confirm this, or am I the only one who has this issue?
    Best regards,
    Daniël Reesing
    Inventor 2013 Pro SP1.1
    Please use plain text.
    *Pro
    Re: 2013 Material physical properties - units
    10-19-2012 03:46 AM in reply to: djreesing
    In the lower left corner of the Material browser you will find this menu:
    Valued Contributor
    10-19-2012 03:47 AM in reply to: djreesing
    Found the solution myself already. At the bottom left corner of the material browser there is an option 'Set Display Units' (see image below).
    Valued Contributor
    10-19-2012 03:48 AM in reply to: sbixler
    You were just a second ahead of me :smileywink:
    Valued Contributor
    JohnK_TEDCF
    10-19-2012 07:21 AM in reply to: djreesing
    One thing to remember when changing the Display Units, is that it applies that change to the entire library and not just that material.  This may or may not be an issue for you.  Just a heads up!
    John Koop
    Software Engineer/ Inventor Specialist
    TEDCF Publishing
    www.trainingtutorial.com
