Hi everyone!!
I'm new here and this is my first post.I hope my problem will be easy to fix.
When i tried to transfer assembly from inventor to showcase by the siute workflows this error displayed
"AdWorkflowHost is unknown.Please check your synhub config file"
I can easy open this assembly in showcase but workflow doesn't work
thanks.
The file referred to in that error message is located in a folder called C:\ProgramData\Autodesk\Synergy - What files do you have there ? What security permissions does that folder & the files within it have ?
You state Inventor 2015 & Showcase 2015 - how were these installed ?
Separate standalone installations ? From Factory Design Suite, From product Design Suite followed by a standalone install of Showcase or otherwise ?
Chris
i have no synerg folder. I installed both versions from the student edition.
I solved the problem by opening the file directly in showcase. But the up-view is the side-view. I found out to rotate the model in showcase... But I have a realy complex model (rendering needs 13 hours in inventor...). So I dont want to wait 13 hours for every click in showcase. It would be better if the orientation works.
You would need to add local lights in Showcase. Lights and decals don't transfer over.
