Hello there,
I'm trying to make circular pattern of the parts welded to the base (part). There is Pattern menu in Weld tab, so I expect that this is for making weld patterns (help leads to standard assembly pattern help page).
When I'm in the "Welds" enviroment, pattern are greyed out, so I created some welds (fillet) and hit the return button. Now pattern menu is availible. But I can't choose anything in the assemly. Moreover, when I select the Weld (in the browser) before, it tells me that: "Select set contains object that cannot be patterned".
Here is GIF:
Solved by j.pavlicek. Go to Solution.
Solved by johnsonshiue. Go to Solution.
Solved by -niels-. Go to Solution.
I don't have that much experience with welds, but i do add them for visual reference from time to time.
As you have noticed, pattern is greyed out when laying welds (in the weld sub-environment) so in order to make a circular pattern weld, you'll probably have to make use of the intermittency option:
Hope that helps, laying welds the way you want can be quite cumbersome...
Niels van der Veer
Inventor professional user & 3DS Max enthusiast
Vault professional user/manager
The Netherlands
Niels van der Veer
The Netherlands
From a quick test i did, i'd say it looks like it...
I did a quick check over on the Inventor ideas, but couldn't find something specifically mentioning this workflow.
Only that the weldment environment could use some improvement...
I can certainly see the "click monkey" amount of work if you have a large pattern type product, so i'd suggest making an idea for this and reporting back here so people can cast a vote for it.
I know i certainly will.
Niels van der Veer
The Netherlands
Vote for: Pattern welds feature (Idea Board)
