I need to make the surfaces on the back of this case smoother. Please see attached picture with arrows pointing at the surfaces, that pretty much need to disapear and make a smooth transition.
Please let me know if you can help.
I would try Delete Face with Heal. But if you post your file (and tell us what version of Inventor you're using), I'll bet someone here can help you figure it out.
Sam B
Inventor 2012 Certified Professional
Please click "Accept as Solution" if this response answers your question.
Inventor Professional 2013 SP1.1 Update 1
Windows XP Pro 32-bit, SP3
HP EliteBook 8730w; 4 GB RAM; Core™ 2 Duo T9400 2.53 GHz; Quadro FX2700M
SpaceExplorer/SpaceNavigator NB, driver 3.7.18
still waiting for a foreshortened radius dimensioning tool in Drawing Manager
Open the file, drag the End of Part marker to the top of the feature tree (which hides all features and makes the file much smaller), save, then attach.
Sam B
Anyone who is making something more complex than a box or cylinder should watch this video.
http://au.autodesk.com/?nd=class&session_id=10379
I recommend starting the part over from scratch following the guidlines from the link posted above.
Your file is more complex and larger file size than needed to create the geometry.
Rebuild All causes many errors and I would use far far fewer (if any) adaptive sketches as they aren't needed.
@Anonymous wrote:I would, but i have till tomorrow to finish it and i wont have time to start over...
That is what my students always tell me.
Then next day (due date) they tell me that they started over at midnight and all went much faster, smoother, better than trying to fight a flawed technique that was flawed from the very first sketch.
Even if you do get it in on time... Someone is going to have fun molding it.
@Anonymous wrote:LOL, trust me, that is not the case... im not a student either.
What do you mean that is not the case.
I am telling you I would start over.
I would spend the next 6 hours doing it correclty.
Time and again I have done exactly that with parts posted here just like yours.
Not my parts - other peoples parts, yet they tell me they don't have the time.
As it is, unfortunately I don't have the time to remodel your part or I would. Just for fun.
I have to agree with JD. My students used to spend hours trying fix a part they created poorly, only to find they could have recreated the part correctly in far less time.
