I am having problems constraining a text object.
When I try to constrain it, I receive error, stating that there was an error occurred while solving the sketch.
Everything appears to be constraint before this.
Can someone give me a hint as to what's causing this problem?
Using Inventor 2024
Solved by Gabriel_Watson. Go to Solution.
Bug. Submit a support ticket so they can investigate further.
It works here:
Related:
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Problems-occurred-...
And:
https://forums.autodesk.com/t5/inventor-forum/quot-dimension-could-not-be-solved-quot-and-quot-refer...
CAD and PLM admin | My ideas | Inventor-Vault Expert GPT (my AI brain)
