Inventor Forum
Thank you AutoDesk.
19 REPLIES 19
Message 1 of 20
mrattray
1041 Views, 19 Replies
Thank you AutoDesk.
Thank you for creating a superior product that knows when I don't really want that last 10 minutes of work I just did.
Mike (not Matt) Rattray
19 REPLIES 19
Message 2 of 20
in reply to: mrattray
Was singing that exact tune yesterday except replace 10 minutes with 15 minutes Smiley Very Happy
Message 3 of 20
Now wait just one cotton-pickin' minute.....we all signed that legal and binding contract when using this software where the catch-all, save their arse phrase of "save often" is listed.
Now in the theme of President Clinton, it depends on what the definition of "often" is.
Obviously it's under 10 minutes in this case.
Message 4 of 20
rhasell
We have all learn't the lesson the hard way, save, save, save.. often. Doing so reduces hangs to almost zero. Smiley Wink
Reg
2025.1.1
Please Accept as a solution / Kudos
Message 5 of 20
in reply to: rhasell
Thats all well and good for what i call a 'hard' crash.
But i sometimes get what i call a 'soft' crash.
Sometimes inventor 'crashes' in the background and lets you keep working away non the wiser.
Then when you reopen...the last hour of saves did nothing.
Used to happen a fair bit back on 2009/2010 but not so often on 2011 and less on 2012
Message 6 of 20
Jason.Amess
I think you'll find that Inventor was so impressed with your desktop picture that it decided you needed another look.... immediately.
Jas
Message 7 of 20
in reply to: Jason.Amess
My personal fav. is when this scenerio happens...
"OK Im just going to extrude this last sketch and then I will save.... "(Extrude Performed), (White Snowy Background Appears), (Blue Ring of Death Appears) CRASH.
Message 8 of 20
mrattray
That's exactly what happened in that photo, except I was just going to deselect that punch center and then save. Of course if it wasn't for IV's random mid-save lunch breaks I wouldn't put off saving. The truly worst part was that I had fixed some faulty geometry right before this and it must have taken me half the morning just to remember what I had done to fix it.
I don't like to make posts like this but I needed to vent and everyone in my office had gone home for the day. This was all I could do to keep my fist out of the monitor.
Message 9 of 20
cbenner
Do you check your processes before forcing Inventor to shut down?  Sometimes what appears to be "Not Responding" and the infamous rolling donut of death... is just a slowdown.  Lots of times it WILL come back if you give it long enough.  Sometimes... not so much.
But... I have to say... Pro E was the worst I've worked with for CTD with no warning whatsoever.
Message 10 of 20
Paul-Mason
What is even more annoying is when Autodesk LOWER END software, NO I'm not knocking or anything like that, AutoCAD has a setting for automatic timed saves with out user interaction.
So the question should be "AUTODESK WHY CAN'T THIS AUTOMATIC SAVE BE INCORPORATED INTO INVENTOR SOONER RATHER THAN LATER??"
May be we should start a petition for this to be included in the next release or two
Inventor 2025 Pro
HP Z420 workstation
Xeon 3.7Ghz CPU 8 Cores, 64 GB Ram
64bit (The Garbage known as) Windows 10 Pro
AMD FirePro V3900 (ATI FireGL) (1GB RAM)
Ashington Northumberland (UK) ~ Home to the WORLD FAMOUS Pitman Painters Group
Message 11 of 20
in reply to: Paul-Mason
Or have it make a Recovery Save (similar to when ACAD crashes) I can understand the problems that can arise (Crash during an Assembly, which parts, sub-assemblies, files, etc... does the program save as Recovery?) But there are always solutions to problems, they just have to figure them out!
Message 12 of 20
mrattray
That's definately the AutoDesk way.
Don't fix the crashes, just include an autosave feature!
I'd like to point out, by the way, that I finally got around to doing a forum search to see why I can't reorder component patterns. I wish I could say I was surprised by the answer. But why fix a basic thing like that when you could just implement an infinately more useful iCloud?!
Message 13 of 20
johnsonshiue
Hi! Did Inventor hang or crash? Do you have the files that can reproduce this behavior? If so, please send them to me and I would like to try it on my machine.
Many thanks!
Software Test Engineer
Message 14 of 20
OMG - NO!!!!!! No to Autosave in Inventor (or any other parametric modeler). Last thing I want to have the CAD program do is save in the middle of me trying to design something, not knowing if that's the path I want to take or not.
I'd much rather risk the crash than have an autosave!
Inventor is used as a design tool, thus autosave would be a killer during the designing stages.
Just save your files when you reach a specific point and it's the result you want.
But then again, you could always give up Inventor and use Solidworks, afterall I hear it butters your toast for you each morning...seriously, just as the two guys I just had this type of discussion with.....ugh. SW must have some very good flavored Kool-Aid they hand out to their users.
Message 15 of 20
Dan,
If I recall, if Inventor does crash you can access the file in the "old versions" folder (or something along those lines) and there you'll find the file as it was right before the crash. Inventor does seem to save the file when a crash happens....or it seemed to at some point.
Message 16 of 20
dan_inv09
(When I hit Reply and have to log in the reply is always to the post at the top of the page with multiple page threads, luckily this is the other post that my reply will be relevant to)
It would have to be a recovery save because as (now I don't know who I was really trying to reply to) said before (or would that be later?) sometimes I'm messing around with a design and just want to see what something would look like if I tried doing something a little different - an autosave could end up being worse than a crash. So maybe in addition to the old versions folder there would be an autosave folder that would work the same way, or something.
Message 17 of 20
mrattray
in reply to: johnsonshiue
It was a hang that it refused to come out of, after waiting several minutes I killed the process and moved on with my life.
I have the files but when I came in the next morning and pulled those files back up I went through the same modeling steps as before (the best I could remember) and IV did not hang or crash. This seems to be a completely random occurence in that I can't find any common denominator between what I'm doing each time it crashes/hangs.
Message 18 of 20
KF090
I agree with CDS.  If I'm in the middle of something heavy I'd rather it NOT try to autosave.
Ever since I started using AutoCAD back in 1992 I've learned to save often.  So I save in between commands, multiple times throughout a string of commands, etc.
I do that with all software that I use, not just AutoDesk software.  Even if they use autosave I would still manually save my work regularly.
Message 19 of 20
I understand the problem with the Autosave and that you may not want to continue from the point of crashing, that is why when it does Autosave (forexample in ACAD) it saves it has (file name)_recovery.  So you have the option of loading up the original file (file last saved before the crash) or the new file (point at which your file crashed).  Giving you the option to continue or to revert back.
Message 20 of 20
rhasell
The Autosave feature in my eyes is a big NO NO. The _recovery is a good idea, but I still use the "Old Versions" as a "Poor man's" Vault. (Don't have the OS to run it in the office. 😞 So Old versions are a god send.)
I mentioned that saving often reduces crashes/hangs to almost zero, my take on it is that UNDO has something to do with it, when you save it must clean out something. I also find that using undo on a complex instruction will cause a hang.
The one thing that does get me is I have one or two drawings that worked fine albeit complex, but will not open anymore, the only way to open them is to defer updates, the second I update the drawing BANG, all gone.
I ran an excercise of deleting individual views before updating, but I ran out of time before finding the ofending view, so the exercise is currently incomplete...
Reg
2025.1.1
