I recently installed Inventor 2019. My preferred font for my drawings is "Century Gothic" which is a standard windows font. Since the install, century gothic text is always italicized regardless of how the text is configured (see image). It works fine in all my other apps. It's only a problem in Inventor. It occurs with my old migrated .idw templates as well as the latest standard .idw template that installed with 2019.
Any help is appreciated.
Solved by eucci. Go to Solution.
Go into the style and standards and show a picture of your "ucci text" standard style..
If you are wondering whether its set as italics in the style settings it is not (see attached). It happens regardless.
Anywhere Century Gothic is used it is italicized. This is not true of other fonts (e.g. Arial)
Hi! Could you share the file here?
Many thanks!
See the attached idw file.
As I mentioned before, It happens with all my idw files.
I'm also attaching a screen shot of what it looks like on my screen.
Hi! I think the issue is probably with the font on your machine. I open the idw file on my machine and I am not seeing the italic effect. Could you check if "Century Gothic" is version 2.35?
Many thanks!
I uninstalled the font and reistalled.
Problem solved.
Strange, the only software that had an issue was Inventor...
