Inventor Forum
sweeping a profile at a compound angle
14 REPLIES 14
Message 1 of 15
1084 Views, 14 Replies
I wnat to sweep the 1.25 dai profile staright thru 3 inches then thru square to compound angled face  . Been struggling with this for a couple of days.
any pointers would be great
thank you
14 REPLIES 14
Message 2 of 15
JDMather
You should indicate that you are using 2013 or you are likely to get solutions that you cannot open.
Also, your Service Packs and Updates are not up-to-date.
Message 3 of 15
in reply to: JDMather
ok I just updated to the new service packs. That file my not reflect that. Just up against the gun on this. If  i could come up with a solution it would get me out of the woods.
Message 4 of 15
2013 inventor is whay i'm using
Message 5 of 15
WHolzwarth
Could look like that, in my imagination.
Walter
Walter Holzwarth
Message 6 of 15
in reply to: WHolzwarth
Wow I think thats it . I will look over how you reproduced this. Looks like not to many steps when you know what your doing. Thank you for taking the time.
Message 7 of 15
Help please
Had to change the angle so I'm still having trouble sweeping the 1.375 dia hole thru square to the compound angled face.Not sure how to create the tool axii to draw the profile sweep.
Message 8 of 15
WHolzwarth
Same as before:
- Work axis through hole, and work point at the hole's bottom
- Work axis through this point, rectangular to the angled face
- New Work plane through both axes
- Use this WP for sketch of sweeping path
- Do subtracting sweep, starting at the top of the existing hole
Walter
Walter Holzwarth
Message 9 of 15
couple of questions . how did u make the 2nd work axix.(one squared to angled face.
What do the sktech lines on the top and bottom of hole represent. does not appear that these are used as part of the sweep geo.
Message 10 of 15
normal to plane thru point. I think i answered my 1st question.
Message 11 of 15
ok now how did you create the work plabe to sketch on. I see you note that you used both axis to create but I'm having trouble duplicating
Message 12 of 15
two coplanar edges . got it I believe.
Message 13 of 15
Walter
Could you look at how I duplicated it. Does not look quite the same but close.
Thank You
Message 14 of 15
WHolzwarth
That's it.
Walter Holzwarth
Message 15 of 15
Thanks for the help. I file this away.
