I am using IV 2010. Does anyone have any stainless steel channel drawn up? Particularly 3 X 4.75#, 4 X 6.69# and 6 X 8.3#. Thanks.
Have you tried looking in content center?
If this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudos are appreciated. Thanks!!!!
All I have in my content center are some ANSI steel and a bunch of other foreign industrial standards none of which appear to be stainless or have the correct profile for a stainless channel. Thanks.
I may be wrong, but I'm pretty sure stainless channels use the same profile as steel channels.
Make sure you don't have any filters preventing you frm seeing what you want to see.
I am not sure they are, the only thing that I have to go by is my old Ryerson stock book and it shows the web, the flange, and the weight being different.
The profile should be the same as ANSI MC/C just insert as custom and then change the material.
I don't even have the sizes your looking for in my Alro book (under SS or HRS).
Also, if the sizes don't match you can change them as well if you insert as custom.
I just use i-Features to place structural components. Then I can just populate it with whatever I need it to be.
