Solved by cwhetten. Go to Solution.
I don't use content center library to many issues I have my own library for this.
You can puplish it to tube and pipe I think. I don't have my drive with me I can upload it tonight or in morning.
In the past I have just used the steel ones that come with Inventor, then I just fudge the drawing parts list to show the correct material.
I have intended to make a stainless library, but have never found the time to do so.
Are there dimensional differences between the steel fittings and stainless ones?
Thanks for the info. I never knew what the "S" was for.
I have only ever used them for skids with small-diameter piping (less than 10"), so the wall thickness was never an issue. And I don't think the difference in material density between carbon steel and stainless steel (on the order of a few thousandths of a pound per cubic inch) is significant (until maybe the 100,000-lb range, and THAT would be a lot of piping).
I would just copy the nearest / closest CC library into your "My Library" and make/edit the changes is size and material there.
We do a lot with Nylon air-brake in the Pipe & Tube module, I just copied an existing flexible library and did my edits to get what I needed. Much easier than creating a library from scratch (unless you do it about once every 1-2 months).
cwhetten wrote: And I don't think the difference in material density between carbon steel and stainless steel (on the order of a few thousandths of a pound per cubic inch) is significant (until maybe the 100,000-lb range, and THAT would be a lot of piping).
If my memory servers me correctly, I think there is a 2% difference in densities. And 2% adds up quickly on the large systems we design.
@dloganbill wrote:
Is there a published workflow for doing that?
Is your content center on a vault server or do you use desktop content?
If you don't already have a custom writeable CC library, then you need to create one. You have to do this from the vault server ADMS console. Once you are logged in to that, you can right-click on the libraries and create a new one.
If you already have a custom writeable CC library, then you are good to go.
Next, you have to make sure that this library (new or not) is available in your project file. In Inventor, go to the projects editor, select your project file, then click on the Configure Content Center Libraries in the bottom right corner (just above the Done button). This will pull up a list of available CC libraries. Make sure the writeable custom library is checked.
Once your writeable library is available, then go to Manage tab > Content Center panel > Content Center Editor. This will launch the editor window that looks similar to the place from CC window. This is where what Blair said comes in. Find the fitting that is closest to what you need. In your case, that's probably the ASME 16.9 butt-welded fittings, since they are the only ANSI butt-welded option. Right-click the part family and choose Copy To > [whatever you named your custom library]. This will copy the entire part family with its family table and folder structure into your library. You can then edit it to your heart's content.
In this case, you will want to edit the family table and change the material, the wall thicknesses, change the schedule designation if you want it to show the "S", filename, part number, description, and anything else I forgot.
