I have an associate's Solid Works assignment attached along with some reference material. I would like to create these 2 spur gears in Inventor using this assignment. I have tried using the gear generator within Inventor but to no avail. It would be most appreciative if someone has a little time to help me with this project. I want to present this to my class as an Inventor assignment in a couple weeks if possible. If you would rather do this in a more direct approach you may use my personal email as well. Jbible00@catt.com We can also attach the final solution to this post for anyone's reference in the end. Thank you.
In Him
John E. Bible - adjunct instructor
IV 2020
Solved by JDMather. Go to Solution.
Here is some reference info:
Do you intend to use the Wellman's Odontograph technique, or do you intend to use the Gear Generator Design Accelerator built into Inventor? (Actually, that is the same technique that Inventor uses with the Gear Generator, but in an automated way rather than manually sketching the tooth profile.)
I'm going to use the Gear Generator Design Accelerator within Inventor. I'll go thru this when I get home tonight. I have watched one of the videos so far.
To get a good handle on the process - actually do the process.
Watching alone suddenly falls apart when you try to do it on your own.
